how can i generate a unique identifier using 1. serial number 2.ID no. and
3. county codes
you can concat() field values
To use this as the instanceID for a survey, you would need to edit the XML
generated by XLSForm.
XLSForm automatically supplies a calculate formula in the bind definition
of the instanceID field. Replace that supplied formula with your concat()
formula.
On Mon, Jul 25, 2016 at 6:38 AM, james macharia wrote:how can i generate a unique identifier using 1. serial number 2.ID no.
and 3. county codes--
