Unique number error checking
Dear ODK group,
I am developing a survey for forest monitoring, one of the inputs is a
unique tree number which is determined in the field. Is there a way we can
code a constraint that stops the input of duplicate tree tag numbers. This
is an error checking requirement.
One possible solution is to have a tree tag number dbase on the phone which
is updated each time a new tree is inputted and is then used to check if
the number has been used already. Is this possible and if so how would I go
about adding this functionality?
Many thanks,
Wesley
··· -- Dr Wesley Roberts jwesroberts@gmail.com Cell: +27(0)83 5355 646 skype: roberts-w
I answered a very similar question yesterday on the
opendatakit-developers list at
https://groups.google.com/d/topic/opendatakit-developers/M6aSNQ9ir3c/discussion.
The punchline is that you can't do this without adding a bit of Java
code.
··· On Wed, Dec 5, 2012 at 6:22 AM, Wesley Roberts wrote: > Dear ODK group, > > I am developing a survey for forest monitoring, one of the inputs is a > unique tree number which is determined in the field. Is there a way we can > code a constraint that stops the input of duplicate tree tag numbers. This > is an error checking requirement. > > One possible solution is to have a tree tag number dbase on the phone which > is updated each time a new tree is inputted and is then used to check if the > number has been used already. Is this possible and if so how would I go > about adding this functionality? > > Many thanks, > Wesley > > > -- > Dr Wesley Roberts > jwesroberts@gmail.com > Cell: +27(0)83 5355 646 > skype: roberts-w > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en
