Hello All,
When using the Validator (version 1.4.6), we get a warning :
Parsing form...
Title: "Instrument No 1 - Pst Questionnaire"
warning: unrecognized data type in xpath expr:
org.javarosa.core.model.data.DateTimeData
Xform parsing completed! See above for any warnings.
Xform is valid! See above for any warnings.
Any idea how to suppress this?
Something is incorrect in your form, or you are using a feature that was
added after 1.4.6.
Download the latest ODK Validate
And see if it gives the same error. If it does, this would indicate that
there is a problem with your form.
If it doesn't, then make sure that you are using the latest ODK Collect, as
your form is using a new feature not found in 1.4.6.
If it is a problem with your form, remove sets of questions from the bottom
of your form until you no longer have the error, then add back in questions
from the last set you removed until you find which question causes the
problem.
On Fri, Jul 15, 2016 at 1:36 AM, geoenginfo wrote:
Hello All,
Parsing form...
Hello Mitch,
We have downloaded the latest validator but we are still getting the same
warning.
Please see the attached xlsform and xform, help us to identify where the
problem could be.
testtbst.xml (1.88 KB)
testtbst.xls (27.5 KB)
On Friday, July 15, 2016 at 11:36:35 AM UTC+3, geoenginfo wrote:
> Hello All,
> Parsing form...
This warning can safely be ignored. When we next update javarosa, it will
contain the fix for this erroneous warning (and a similar one for TimeData)
On Fri, Jul 15, 2016 at 1:43 PM, geoenginfo wrote:
Hello Mitch,
warning.
problem could be.
Hello All,
Parsing form...
