There is an updated ODK 2.0 Sync APK available on the downloads page:
This "rev 128" update to this APK fixes an issue reading gzip data and is
designed to work with the "rev 126" tools suite.
ie This "rev 128" update to this APK fixes an issue reading gzip data
Can you describe the issue in more detail? I recently installed aggregate/tomcat and was seeing various issues when doing reset server using synch 126 and the sample apps. Just wondering if this issue could be causing some of the issues?
When data is sent to the Sync app from Aggregate, it is typically
compressed using the gzip format to save bandwidth and time. The
GZipHandler that we were using did not correctly read all the data. It
performed one read and then stopped. If all the data could be retrieved in
one read, the user would see no issues. However, if multiple reads were
necessary to get all of the data, the user would see an error message
similar to the one below.
ODK SYNC ERROR tables
There were failures. Status: NETWORK_ERROR Reason:
This error message is not very descriptive, and it is possible for this
error to be thrown for other reasons.
The fix was to make the GZipHandler read the stream as many times as
necessary to retrieve all of the data.
Clarice
https://opendatakit.org/downloads/download-info/odk-sync-apk/#
This "rev 128"
update to this APK fixes an issue reading gzip data and is designed to
work with the "rev 126" tools suite.--
Clarice Larson
clar...@gmail.comie This "rev 128" update to this APK fixes an issue reading gzip data
causing some of the issues?--
"ODK Developers" group.
