Hi ODK forum, I decided to take this time when a lot of us are pausing data collection to update my version of Aggregate, something I have not been very good at keeping on top of. I had Aggregate v1.4.15, running on my google app engine. I have made an attempt to update to v.1.7.4, and it seemed to be successful according to the updater (see screenshot). However, when I return to my server, I receive the app engine application error message (see screenshot).
-Previously had Aggregate v1.4.15, tried to update to v1.7.4
-Google App Engine to host my server.
-Java v8 update 231.
The AppEngine Error screen is one I've received often when I've uploaded too many versions of a survey in the field within 1 day, and I know that it resets within 24 hours. So the first thing I did was wait 24 hours and checked again, the problem remains. I also checked my billing status, I have not exceeded any limits, and I have the server set up with an active credit card.
In the google console, I am seeing an error, titled: BeanCreationException: Error creating bean with name 'hierarchicalRoleRelationships' defined in ServletContext resource
See last 2 screenshots with those errors.
The last thing I tried was to update to an earlier version of Aggregate, (v1.7.1), or just re-install what I had before (v1.4.15) by running those installers. Finally I worried that my instance name was not correct because in my notes I had it capitalized (NDIGD) but perhaps it should have been lower case. I tried both ways, and I even tried using my project name as the instance name. All of these attempts have failed and when I try to access my server I see the same message.
I don't think this problem can be reproduced outside of my machine and server.
Screenshots are below. Thank you for your help on this!
