I am using the "begin group" command to put multiple questions on a page
and it working ok.
But having a few problems when this is used in conjunction with other
commands
For example when using "add select one prompt" but with an appearance of
"minimal" on its own works fine, but when in a group on the same page as
anoth question, it will not render.
I am also having a similar problem with "add select multiple prompt" with
the option of "or_other" as this works ok on its own but when in a group
it does not render an "other" page after the question. But if you go
backwards a page you can see that the "other" box is rendering between the
questions.
Is there any way around this as both these feature would be usefull in a
grouped set of questions, is it the table-list orfield-list appearances i
am using that is conflicting?
Hi Jon,
Could you attach the spreadsheet you are using or send it to me so I can
take a closer look at these issues?
-Nathan Breit
On Friday, June 8, 2012 4:49:31 AM UTC-7, Jon Parsons wrote:
> Hi
> and it working ok.
> commands
> questions.
> Any help much appreciated
> Jon
and it working ok.
commands
questions.
Jon
Hi
and it working ok.
commands
questions.
Jon
these are the final files for the form - not showing the errors - but if
you change the stlyes within these groups you will be able to re create
thanks
Jon
On Friday, 8 June 2012 18:31:08 UTC+1, Nathan wrote:
> Hi Jon,
> Thanks,
> -Nathan Breit
>> Hi
>> and it working ok.
>> commands
>> questions.
>> Jon
> Hi Jon,
> Thanks,
> -Nathan Breit
>> Hi
>> and it working ok.
>> commands
>> questions.
>> Jon
Thanks Jon.
I'm unable to reproduce the bug involving a select one question with
appearance set to 'minimal' inside a group with a 'field-list' appearance.
It seems to work fine for me. It could be an issue with your phone, or
version of Collect if it is older than 1.1.7. Also, XLSForm does not check
the that the appearance field matches a known setting, so watch out for
spelling mistakes.
I think the or_other bug is caused by the 'specify other' question being
included in field-list. Since field-lists cannot dynamically change while
you are on the page, and 'specify other' is set to be relevant based on
another question on the page, the question will not show up until you leave
it and come back to it. For now I recommend creating your own 'other'
option for selects in field-lists, either by putting the 'specify other'
question after the field-list, or keeping it in the field list but making
it always relevant.
Regards,
-Nathan
On Monday, June 11, 2012 3:43:04 AM UTC-7, Jon Parsons wrote:
> Hi Nathan
> Thanks for the offer of assistance
> find link below to dropbox files in a public area
> http://dl.dropbox.com/u/44226168/rotational-farming-draft-3.xls
> http://dl.dropbox.com/u/44226168/rotational-farming-draft-3.xml
> thanks
> Jon
>> Hi Jon,
>> Thanks,
>> -Nathan Breit
>>> Hi
>>> and it working ok.
>>> commands
>>> with the option of "or_other" as this works ok on its own but when in a
>>> group it does not render an "other" page after the question. But if you go
>>> questions.
>>> Jon
>> Hi Jon,
>> Thanks,
>> -Nathan Breit
>>> Hi
>>> and it working ok.
>>> commands
>>> questions.
>>> Jon
