Hi devs,
I want to bring to the floor, a discussion Chris and I have been having
about collecting the username used to authenticate for a form and add it to
the submitted record.
It seems that a proper solution would be to follow the OpenRosa Metadata
schema https://bitbucket.org/javarosa/javarosa/wiki/OpenRosaMetaDataSchemaand use a similar approach as for instanceID (though without the
calculate
of course ;)). Basically all we'd need to do is add the meta
node:
Like with instanceID, a binding is not necessary and imho better not to
include. A client should populate these known meta nodes if they are
present. It seems Aggregate/Validate accepts this just fine too. See a full
XForm file attached to this post.
Any thoughts, suggestions?
One question is whether we should perhaps prefix the user name with the
client name: enketo.org:johndoe, odkcollect:johndoe, ctocollect:johndoe,
like Dimagi appears to be doing.
Cheers,
Martijn
New_Meta_Node_Test.xml (890 Bytes)
Hi Martijn,
Seems fine to me. Only complaint is that the spec says domain name, so
it should be surveycto.org:userid.
On Fri, Feb 28, 2014 at 8:41 AM, Martijn van de Rijdt martijn@enketo.org wrote:
Hi devs,
schema and use a similar approach as for instanceID (though without the
calculate
node:
Cheers,
Martijn
"ODK Developers" group.
Hi Martijn,
I approached this problem somewhat differently.
In my forms the user's name appears in several fields and I wanted these
fields to be auto-populated. The solution I went with was to include a
sentinel element in the form's XML (specifically: <_auto_gen_01/>) and then
to pre-process the XML prior to it being loaded. The pre-process method is
invoked from FormLoaderTask.doInBackground(), and its function is to
replace "<_auto_gen_01/>" with "<_auto_gen_01>Username<_auto_gen_01/>" in
the instance section of the form's XML. The value of Username is obtained
from a Preference which has been set prior. The <_auto_gen_01> node does
not appear visually in the form, hence it is meta data. Fields in the form
which require the username use a calculate() to obtain it from the value of
the <_auto_gen_01> node. Works well.
Leon
On Saturday, 1 March 2014 00:41:55 UTC+8, Martijn van de Rijdt wrote:
> Hi devs,
> schemaand use a similar approach as for instanceID (though without the
> `calculate` of course ;)). Basically all we'd need to do is add the meta
> node:
> Cheers,
> Martijn
Thanks Yaw,
I'll go ahead with this then and will use "enketo.org:" prefix for the
enketo.org service. The key is probably to make sure it's unique, so if
it's deployed in formhub for their own enketo service, I'll use "
enketo.formhub.org:" as prefix.
On Sun, Mar 2, 2014 at 9:27 PM, Yaw Anokwa wrote:
Hi Martijn,
Hi devs,
to
calculate
node:
full
Cheers,
Martijn
https://groups.google.com/d/topic/opendatakit-developers/tlmvM7tjsJI/unsubscribe
Did you know that Enketo Smart Paper has now become the #1 tool for data
collection? Don't fall behind. Use it!
Enketo https://enketo.org |
LinkedInhttp://www.linkedin.com/company/enketo-llc |
GitHub https://github.com/MartijnR | Twitterhttps://twitter.com/enketo
Martijn and Leon,
Now that I think about it, you can get userid or email already with
It's not in the metadata
Any reason why the above wouldn't work?
On Mon, Mar 3, 2014 at 4:36 PM, Leon Wende leon.wende@gmail.com wrote:
Hi Martijn,
invoked from FormLoaderTask.doInBackground(), and its function is to replace
"<_auto_gen_01/>" with "<_auto_gen_01>Username<_auto_gen_01/>" in the
instance section of the form's XML. The value of Username is obtained from a
Preference which has been set prior. The <_auto_gen_01> node does not appear
visually in the form, hence it is meta data. Fields in the form which
require the username use a calculate() to obtain it from the value of the
Leon
Hi devs,
calculate
node:
Cheers,
Martijn
Okay, and we'll add this to the queue for SurveyCTO. We can contribute the
Collect and pyxform changes.
Chris
On Mon, Mar 3, 2014 at 11:40 AM, Martijn van de Rijdt wrote:
Thanks Yaw,
On Sun, Mar 2, 2014 at 9:27 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Hi Martijn,
Hi devs,
it to
calculate
node:
full
ctocollect:johndoe,
Cheers,
Martijn
Groups
an
Enketo https://enketo.org | LinkedInhttp://www.linkedin.com/company/enketo-llc |
Thanks Yaw,
In my case, the username value is a custom string that the user has entered
previously, and could even legitimately be a nickname. Hence there is no
existing preload property from which I could get this value.
I appreciate your idea though. Is there a list of the available
preloadParams?
Leon
On Tuesday, 4 March 2014 08:44:29 UTC+8, Yaw Anokwa wrote:
> Martijn and Leon,
> jr:preloadParams="userid"/>
> jr:preloadParams="email"/>
> It's not in the metadata jr:preload="property" jr:preloadParams="userid"/>
> Yaw
> On Mon, Mar 3, 2014 at 4:36 PM, Leon Wende <leon....@gmail.com> wrote:
> > Hi Martijn,
> then
> is
> replace
> from a
> appear
> the
> > Leon
> >> Hi devs,
> having
> it to
> Metadata
> meta
> >> node:
> full
> ctocollect:johndoe,
> >> Cheers,
> >> Martijn
> Groups
> an
That awesome Chris. Thanks!
Chris
On Mon, Mar 3, 2014 at 11:40 AM, Martijn van de Rijdt martijn@enketo.orgwrote:
Thanks Yaw,
Hi Martijn,
Hi devs,
having
it to
Metadata
calculate
meta
node:
full
ctocollect:johndoe,
Cheers,
Martijn
Groups
an
Leon,
http://opendatakit.org/help/form-design/examples/#preload_params has a
list, but I usually check the source. I think it's called
PropertyManager.java or something along those lines...
On Mon, Mar 3, 2014 at 4:50 PM, Leon Wende leon.wende@gmail.com wrote:
Thanks Yaw,
preloadParams?
Leon
Martijn and Leon,
On Mon, Mar 3, 2014 at 4:36 PM, Leon Wende leon....@gmail.com wrote:
Hi Martijn,
then
is
replace
from a
appear
the
Leon
Hi devs,
having
it to
Metadata
calculate
meta
node:
full
ctocollect:johndoe,
Cheers,
Martijn
Groups
an
I somehow thought the username preloader wasn't implemented in Collect.
Thanks Yaw. I guess, I should use this, unless this preloader has been so
obscure that it hasn't really been used && we want to slowly start a
movement away from preloaders.... Do we?
FWIW, technically, I much prefer using the MetaData schemahttps://bitbucket.org/javarosa/javarosa/wiki/OpenRosaMetaDataSchema,
i.e. fixed nodenames at fixed location inside a fixed meta group, instead
of preloaders. The reason for this is that we don't *want *any flexibility
for these fixed meta data. Bindings are better left out completely (and
ignored if there). E.g. adding an incorrect calculation for any of these
meta data could really mess up the collected data. We can protect against
it but there is just a higher chance of bugs if we can't ignore the binding
completely as we have to get the preload parameters. Another (bigger)
advantage, is that we can (easily) choose to populate some nodes on the
server instead of the client for a higher reliability. The latter would be
preferable in the case of a userID. In the case of Enketo, the "server"
could be Enketo's server that routes submissions to Aggregate.
On Monday, March 3, 2014 5:55:56 PM UTC-7, Yaw Anokwa wrote:
> Leon,
> Yaw
> On Mon, Mar 3, 2014 at 4:50 PM, Leon Wende <leon....@gmail.com> wrote:
> > Thanks Yaw,
> entered
> > preloadParams?
> > Thanks,
> > Leon
> >> Martijn and Leon,
> >> It's not in the metadata >> jr:preload="property" jr:preloadParams="userid"/>
> >> Yaw
> >> On Mon, Mar 3, 2014 at 4:36 PM, Leon Wende wrote:
> >> > Hi Martijn,
> these
> a
> and
> >> > then
> method
> >> > is
> >> > replace
> >> > from a
> >> > appear
> >> > the
> >> > Leon
> >> >> Hi devs,
> >> >> having
> add
> >> >> it to
> >> >> Metadata
> the
> >> >> meta
> >> >> node:
> to
> a
> >> >> full
> the
> >> >> ctocollect:johndoe,
> >> >> Cheers,
> >> >> Martijn
> >> > Groups
> send
> >> > an
> Groups
> an
Sure enough! I confirmed that XLSForm supports a "username" field type that
maps into this. It works, but it gives an annoying warning if you don't
give a thoroughly unnecessary label.
Chris
On Mon, Mar 3, 2014 at 7:55 PM, Yaw Anokwa wrote:
Leon,
Thanks Yaw,
entered
preloadParams?
Leon
Martijn and Leon,
Hi Martijn,
these
then
method
is
replace
from a
appear
the
Leon
Hi devs,
having
it to
Metadata
the
calculate
meta
node:
to
a
full
the
ctocollect:johndoe,
Cheers,
Martijn
Groups
an
Well, thanks for discovering this Chris!
So I presume you'd rather improve that existing functionality in XLSForm
then, instead of adding a userID meta node? I am still wishing we could at
least force the preload items inside the meta group with a fixed node name
according to the metadata schema (in XLSForm).
that maps into this. It works, but it gives an annoying warning if you
don't give a thoroughly unnecessary label.
Chris
On Mon, Mar 3, 2014 at 7:55 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Leon,
Thanks Yaw,
entered
preloadParams?
Leon
Martijn and Leon,
Hi Martijn,
these
a
and
then
method
is
replace
from a
appear
the
Leon
Hi devs,
having
add
it to
Metadata
the
calculate
meta
node:
not to
See a
full
the
ctocollect:johndoe,
Cheers,
Martijn
Groups
send
an
Groups
an
Being of the "if it ain't broke, don't fix it" school, I somewhat regret
the time we already spent on this (having implemented a username()
function). Clearly we should look more closely before assuming that
something doesn't already exist.
I can easily believe that this stuff could be implemented better, but I'm
not seeing a business case for re-architecting it. We only had 1-2 clients
who needed to grab the username, and apparently they could have already
done it..!
Chris
On Tue, Mar 4, 2014 at 3:43 PM, Christopher Robert crobert@surveycto.comwrote:
Chris
Leon,
Thanks Yaw,
entered
no
preloadParams?
Leon
Martijn and Leon,
Hi Martijn,
these
include a
and
then
method
is
replace
the
obtained
from a
not
appear
which
of
the
Leon
Hi devs,
having
add
it to
Metadata
without the
calculate
meta
node:
not to
are
See a
full
with the
ctocollect:johndoe,
Cheers,
Martijn
Groups
send
an
Groups
an
an email to opendatakit-developers+unsubscribe@googlegroups.com.
