I've added a choice filter to my survey. When I tested it, it was working but all of my labels for all of my questions became blank. It was like the column "choice_filter" was like a toggle. When I add the "choice_filter" column, all labels become blank but as soon as a I remove it, all the labels reappear. Can someone explain the cause of this and how to fix it?
Thank you,
Ryan
Nevermind, I just got it...
In my label column, I was using "label::English" instead of "label". As soon as I changed it, the labels all reappeared. If I was using different languages in a survey, how would I use a choice_filter then? Would I need to put "choice_filter::English"?
Ryan
> Thank you,
> Ryan
Hi Ryan,
Attached is a sample form with choice_filters and multiple languages.
choice_filter filters on the name/value so you never need a ::language
on it. You need those on labels though.
select_one_external.xlsx (10.7 KB)
>> Thank you,
>> Ryan
> Ryan
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com.
