I have a select_one question (What is your primary source for irrigation water?) and then a follow up select_multiple question (What are your OTHER sources of irrigation water)? I have a choice filter on the second question such that only those choices NOT selected in the first question are among the choices in the second question. In addition (and here is the problem), I would also like an "other" response on the second question, but it seems to be not appearing because of the choice filter. Can I do both the choice filter and the or_other option?
ODK on Macbook Pro
I have tried the above configuration.
Explained above.
Can you try this, sorry I'm not on my computer or else I would try it out for you. But, in the "name" column on your choices tab, does the "other" choice in question number one have the same 'name' as your "other" choice from question two? For example, if the name from first choice list was 'other1', and the name in the second choice list was 'other2'... Does that work?
Hi @dbk ,
Thanks for the XLSForm, that's super helpful. Yes, I see what you mean with the choice_filter seeming to interfere with the or_other functionality!
Please see attached XLSForm, which I think acts the way you want it to.
To do it, I:
removed the or_other from your second question, and
made a second choice-list (duplicate) for your second question, so it didn't interfere with choice-list of your first question by adding 'Other' manually,
added 'other2' as the name for 'Other' in the second choice list, and then
added the pop-up question for Other to appear after the second question (using selected(${field_irrigate_source},'other2') in the relevant column)
This now functions as expected. Not sure if there's anyone who can explain the choice-filter and or_other not working simultaneously? Perhaps a more elegant solution out there...
However, this at least allows the functionality for now...hope it's helpful!
