Hi, everyone! First question to the group. Please let me know if there are
some conventions I haven't followed.
I am currently using XLSForm. I have a select_multiple question that then
forms the basis for a repeat that repeats a count-selected number of
times.I would like to use the label for each choice within the label for
the survey.
Should say "within survey labels inside a repeat" in the subject line...
> the survey.
> For example:
> Did you eat any of the following today?
> dates
> figs
> {User selects both}
> How many dates did you eat?
> Were they tasty?
> How many figs did you eat?
> Were they tasty?
> Appreciate any help you could provide!
> Curtis
Hi? If the top of fruit eaten was a text field, you could easily insert
${with name of question} within the question how many ${with name of
question} did you eat?
How ever since it's a multiple select, doing so will give a number if
multiple choice is coded. However I think it will work if the name of the
choice reflects the label eg label Fig is named Fig.
Louis....
the survey.
This cannot be done for select-multiple fields, but can be done with
select-one fields.
And doing that is poorly supported within XLSForm.
The ${field} within the question label is expanded in the generated XML to
be something like:
You can manually edit the generated XML to change this to be a relative
path (using ../...) to the field (so that it works within a repeat group).
If the question were a select-one, you could write, e.g.,:
and this would display the choice text for that select-one field (rather
than the choice value).
However, there is no function available to map all the values in a
select-multiple into a list of text labels.
If your values and text are the same, then you could just display the list
(which will be space-separated). But the values cannot contain spaces.
are some conventions I haven't followed.
the survey.
I'm comfortable editing in the XML. XLSForm is just super convenient for
the basic stuff.
Is there someway to use something like a join function with jr:choice-name
to make a list of selections and then loop through those in the repeat? I
gather that the answer is no, but I figured I might rephrase a different
way and see if that makes more sense.
This is an interviewer run survey, so displaying a list of the selections
wouldn't be the end of the world. How would I generate a space-separated
list of the selected values?
Thanks!
> select-one fields.
> be something like:
>> Louis....
>>> then forms the basis for a repeat that repeats a count-selected number of
>>> the survey.
>>> For example:
>>> dates
>>> figs
>>> {User selects both}
>>> Were they tasty?
>>> Were they tasty?
>>> Curtis
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
That's the crux of the problem. There is no function in javarosa that can
do that.
the basic stuff.
Thanks!
select-one fields.
to be something like:
list (which will be space-separated). But the values cannot contain spaces.
the survey.
Groups "ODK Community" group.
the basic stuff.
gather that the answer is no, but I figured I might rephrase a different way
Thanks!
select-one fields.
times.I would like to use the label for each choice within the label for the
survey.
A mix of the join() functionality and jr:choice-name to operate on a
select-multiple.
Generally a boilerplate copy-and-paste with the implementation doing a
split on space to get the individual values in the select-multiple to
convert.
On Wed, Aug 17, 2016 at 1:55 PM, Yaw Anokwa wrote:
Hi Mitch,
Any sense of how hard it'd be to add?
in-field training, and software development for ODK. Go to https://nafundi.com to get started.
for
the basic stuff.
jr:choice-name
I
different way
selections
space-separated
Thanks!
select-one fields.
XML
relative
group).
(rather
spaces.
insert
if
the
line...
there
number of
for the
survey.
send
send
