I used Excel to create my XML form but when we try to upload the XML form
to FieldTask we get the error:
XPath evaluation: cannot handle function 'uuid'
Any suggestions?
Thanks so much!
Lisa
Any suggestions?
Thanks so much!
Lisa
I should also add... the form works well when we use ODK Collect; just a
problem when we use FieldTask
Sounds like an issue you should take up with the FieldTask folks...
Good point. I am new to this - can point me in the direction of any
contact information for them?
http://code.google.com/p/smap-suite/
We are still having trouble and are in conversation with the developers
from field task but I thought I would also ask the following.
We are trying to export data entry form field to a variant of ODK Collect
called Field Task. The UI is identical and our understanding is that field
task incorporates the use of Open Street Maps.
Transfer from ODK build into this modified ODK Collect application does not
result in errors, however when we do it using the Excel builder utility we
get an error message:
I am wondering if perhaps Field Task was created using an older version of
ODK Collect (probably from about 6-8 months ago?). Have you run in to any
similar errors? Any insight?
Many thanks!
I should follow up and emphasize that it seems like ODK build and the Excel
Builder Utility are producing 2 different forms... is this possible?
Yes, this is very possible and highly likely as they are maintained by
completely different community members and are quite divergent in goals
(Build for quick/simple forms with a graphical UI; XLSform for larger more
complex forms).
Gaetano
Excel Builder Utility are producing 2 different forms... is this possible?On Friday, September 14, 2012 10:11:39 AM UTC-7, Lisa Zook wrote:
from field task but I thought I would also ask the following.We are trying to export data entry form field to a variant of ODK Collect
task incorporates the use of Open Street Maps.Transfer from ODK build into this modified ODK Collect application does
not result in errors, however when we do it using the Excel builder utility
we get an error message:
XPath evaluation: cannot handle function 'uuid'I am wondering if perhaps Field Task was created using an older version
of ODK Collect (probably from about 6-8 months ago?). Have you run in to
any similar errors? Any insight?Many thanks!
On Friday, August 31, 2012 10:42:01 AM UTC-7, Yaw Anokwa wrote:
http://code.google.com/p/smap-**suite/http://code.google.com/p/smap-suite/
contact
information for them?On Friday, August 31, 2012 10:37:45 AM UTC-7, Yaw Anokwa wrote:
just a
problem when we use FieldTaskOn Friday, August 31, 2012 10:31:42 AM UTC-7, Lisa Zook wrote:
XML
form
to FieldTask we get the error:XPath evaluation: cannot handle function 'uuid'
Any suggestions?
Thanks so much!
Lisa--
Unsubscribe: opendatakit...@googlegroups.**com
Options: http://groups.google.com/**group/opendatakit?hl=enhttp://groups.google.com/group/opendatakit?hl=en--
The uuid() method was added to the form processor library (javarosa) at
least a year and a half ago, so "Field Task" must be using a very old
version of the form processor library.
That library has changed significantly in the last 3 months (e.g., added
support for [efficient] cascading selects).
complex forms).Gaetano
Collect called Field Task. The UI is identical and our understanding is
that field task incorporates the use of Open Street Maps.Transfer from ODK build into this modified ODK Collect application does
contact
just a
XML
form
Any suggestions?
Thanks so much!
Lisa--
Hi guys thanks for helping out here. fieldTask is built with odk 1.2.1,
Lisa has emailed me directly and I'm looking at the problem.
regards
Neil
version of the form processor library.That library has changed significantly in the last 3 months (e.g., added
support for [efficient] cascading selects).Mitch
On Fri, Sep 14, 2012 at 10:35 AM, Gaetano Borriello < gaetano@cs.washington.edu> wrote:
contact
just a
XML
form
Any suggestions?
Thanks so much!
Lisa--
mitchellsundt@gmail.com--
