I have the following case, I have a loop that collects information about
family members like age, gender, and other related info. What I aim to do
is to have the number of babies under age 2 + plus the total number of
children under age 5.
My issue is that I don't have specific index to pass to the indexed-repeat
function to get any thing, I'm not sure if my case is supported by ODK.
On Wednesday, August 12, 2015 at 7:48:36 AM UTC-6, Hanan Aqilan wrote:
> Hi,
> Your help is greatly appreciated!
> Thanks,-Hanan
Please share with me the excel sheet to have a look at how it is designed.
Bunch of thanks Marti!
On Wednesday, August 12, 2015 at 4:48:36 PM UTC+3, Hanan Aqilan wrote:
> Hi,
> Thanks,-Hanan
What if I want for example to calculate the number of babies under age 2, I
want to do summation but by filtering the results by age. Can I do this?
Bear with me please as I'm novice to ODK...
> Hi,
> Thanks,-Hanan
To clear it up. I want to filter but outside the loop not inside as stated
in your sample excel. Can I do this?
> Hi,
> Thanks,-Hanan
Ya will try it out and post back the results here.
Thank ya.
> Hi,
> Thanks,-Hanan
> Hi,
> I have the following case, I have a loop that collects information about family members like age, gender, and other related info. What I aim to do is to have the number of babies under age 2 + plus the total number of children under age 5.
> My issue is that I don't have specific index to pass to the indexed-repeat function to get any thing, I'm not sure if my case is supported by ODK.
> Thanks,-Hanan
The second link in my previous message was to the XLSForm.
Good luck,
Martijn
On Thursday, August 13, 2015 at 11:29:23 AM UTC-6, Hanan Aqilan wrote:
> Excitement!
>> Hi,
>> supported by ODK.
>> Thanks,-Hanan
Yes, you can filter this afterwards as well. This is actually a simpler,
more elegant method, but the disadvantage is that you have to revert to
using XPath syntax. There is no XLSForm shortcut syntax for it.
Filter results like this: count(/data/member[age < 5])
See
(I haven't tested this in ODK Collect. Best to check this before investing
much time in using this method.)
Cheers,
Martijn
supported by ODK.
It is not clear (to me) what you want to do. Best to create a test form (as
short as possible) with your attempt, if you want others to look at
finding a solution. Does it have anything to do with this discussion? If
not, create a new thread.
supported by ODK.
Thanks,-Hanan
hi i have this indexed repeat i want to just repeat this all group of
house hold member but the index repeat does not any help please
