I am quite new with the ODK aggregate and i am doing project that uses an
access database.
My question is, can ODK aggregate work with the access db or does it only
work with SQL?
Users of the ODK collect upload forms onto Formhub and formhub is normally
quite congested so I was wondering
if the ODK forms could be uploaded straight into the database if I am using
Access?
Anyone who can help? I'd really appreciate.
As far as I am aware the only db options are MySQL and postgres. To get the data into access you would need to do some post processing. Another option would be to use Google app engine and stream the data to Google spreadsheet of fusion tables.
Bashir
From: opendatakit@googlegroups.com [mailto:opendatakit@googlegroups.com] On Behalf Of Tracy Kay
Sent: 13 August 2014 10:19 AM
To: opendatakit@googlegroups.com
Subject: [ODK Community] Using ODK Aggregate With an Access Database
Hi Guys,
I am quite new with the ODK aggregate and i am doing project that uses an access database.
My question is, can ODK aggregate work with the access db or does it only work with SQL?
Users of the ODK collect upload forms onto Formhub and formhub is normally quite congested so I was wondering
if the ODK forms could be uploaded straight into the database if I am using Access?
Hi tracy, where yo able to get a work around, on using access instead of
mysql
On Wednesday, 13 August 2014 11:19:21 UTC+3, Tracy Kay wrote:
> Hi Guys,
> access database.
> work with SQL?
> using Access?
> Tracy
I was not able to do so, are you facing the same problem?
mysql
Hi Guys,
an access database.
work with SQL?
using Access?
ODK Aggregate only works with MySQL, PostgreSQL and on AppEngine.
Once you have ODK Aggregate set up, there are various publishing and
data-export options that you can use to move the data into an Access
database or other tool.
On Wed, Jul 1, 2015 at 5:44 AM, Tracy Kimani wrote:
Hi Ayoub,
mysql
Hi Guys,
an access database.
only work with SQL?
using Access?
