We are having a terrible time trying to get an ODK Central server set up in China. Many things are easier there; many things are harder. There are extra licensing steps to getting (or using!) an IP name, for instance.
Question: what are the options for using ODK collect without a proper ODK Central server?
I am thinking:
Is there such a thing as a self-signed certificate, assigned for an IP address without a domain name, that one could install on a field laptop, whose LAN IP address would change with changing hotels (or a consistent LAN IP address; I guess that could be arranged by a router or something)?
Then could we nightly connect tablets to the laptop rather than to an ODK Central on the Internet?
I have very limited knowledge of how certificates, etc work, and we had been hoping to just use the automated one that the installation script seems to get.
Hello ceebeelee, i think this trick - workaround could be what you are looking for.
I've try it once (just for teh sake of experimentation) and the trick was working.
If you can access to Google sheets, it should be an option.
Of course you will not get the management features embeded on Central but at least you will be able to collect and upload data to Google Sheets.
Wow, thank you Neri,
That is really neat.
Alas, Google cannot be easily accessed from China, and we need to have the data storage stay within China for this project. It's also not a "small project," I suppose.
So I'm still looking for a trick to use a mobile ODK Central, most likely...
Hi Yaw!
Hm, that is a good question. I think even though we will have two teams, they will always be in the same hotel as each other each evening, so yes.
Twenty-five tablets, total.
Chris
Use ODK Briefcase and you can pull the submissions from each device via a USB cable. Then you export the submissions to CSV or push them to a Central server when you are out of country. It's not great for form management, but if you aren't changing your forms, it's not terrible.
Register a domain name in the US and get a long-lived cert. Install that cert on the laptop with Central and connect the laptop and phones to a router with OpenWRT installed (or another computer on the same network with a DNS server like dnsmasq). In OpenWRT or on computer with DNS server, map the domain name to the server.
Try ona.io or kobotoolbox.org. I'm not sure they work inside China, but it's easy enough to try.
Once they are built, all you do is plug them in and join your devices to the wifi network and you're off to the races. No internet required. This was running NEMO but it could run Central just as easily.
Happy to share some documentation on this if you're interested, just @ me.
One thing to keep in mind about SSL certs now is that as far as I know the longest you can get them for now is a year. You can pay for 5 years at once but you still have to re-issue the cert each year. So we just have an annual maintenance period where we update the cert and the software on the server and etc.
