Hello,
I am trying to use Open data kit to register and confirm registered farmers for the purpose of distribution of benefits. I am sure there is no problem using forms to register new people, but I would like to have more information on how to ensured that only registered farmers in a database are authenticated through biometric means( face, barcode, voice etc) before they can be given their benefits. date and time of farmers authentication must also be noted offline. The representative can then move to network area to upload authenticated database to aggregate server. I would like to work with anyone who can ensure this and other functions on the open data kit apps
Verification of identity is not something ODK tools provide - that would
require an external app (e.g., fingerprint scanner) that would provide an
identity code.
Also, the tools are, by default, not secured against tampering or fraud.
While the core platform may be a starting point for whatever application
you build, it will require extensive customization to fully protect against
tampering and fraud. It probably also requires additional server support
to fully achieve this.
You should do a requirements and security audit of the Android platform and
the ODK tools you intend to use before using them for anything involving
money transfers or accounting.
On Sun, Mar 6, 2016 at 6:04 AM, wrote:
Hello,
kit apps
