I have tables with hundreds of rows that are searched numerous times in my survey, making the whole algorithm unusably slow. Until now I was putting the tables in the choices list. I understand that using csv files will be much faster. I successfully implemented such a solution using pulldata() in a calculate field. However, I need to use regular expressions to find the right row to pickup. For example I will have a rows with minimum and maximum age ( 'age_min', 'age_max'). There is no pulldata functionality to solve that problem, as it can only pick up statically defined fields.
I would like to use serch() in the calculate field with an expression like: ${user_age} >= age_min and ${user_age} < age_max.
But I have not found any case where search is used in calculate, nor have I found documentation about search() function variables.
I would like to know if someone can help out, providing documentation, use cases or suggesting other solutions.
odk collect and enketo. Once finished I am planing to upload it to Commcare.
pulldate, internal tables
