Dears
I am using simple repeat ( not related to any other questions) when by mistake I am clicking Add group, how to solve this issue.
Regards
Dear @Luat
Please see the documentation on repeats and repeat recipes and tricks
Your question is not clear, if you are still facing problems after going through the documentation, please:
- share your form or sub section of the form with the problem
- describe a high level use case of what you are trying to do? What you have done, what you expected and and what you got
Best
Ronald
Thank you @Ronald_Munjoma
I have repeat group in row 6 and in row 7 am asking about name of item and other questions when i finish from the first item and move forward if by mistake i hit add one more item, in this case how to deal with this new item added by mistake,
Pleas see attachedTEST.xls (39.5 KB)
To remove a repeat, you can long press on the question label in the same way as for removing answers or clicking the "remove" button in the jump menu. See https://docs.getodk.org/collect-filling-forms/#removing-instances-of-repeats for a screenshot.
