Here is a scenario:
- If you select yes in any two questions from Q1 it takes you to Q2 otherwise if no is selected for all in Q1 the survey ends
*If you select yes in any two questions from Q2, it takes you to Q3, Otherwise if no is selected for all in Q2 then the survey ends
- if you select yes in any three questions from Q3 it takes you to the main survey in Section B. If no is selected for all in Q3 then the survey ends
NB: The link below presents the scenario that is working perfectly.
Visit: enketo.getodk.org/preview?form=https%3A//xlsform.getodk.org/downloads/946bbpki/XLS%20skip%20example.xml
But now from the previous task,
i grouped all questions from Q1 and Q2 in a matrix form (named Section Ai)
I grouped all questions from Q3 in a matrix form (named Section Aii)
What am i trying to achieve?
if you select a yes from any questions in the first matrix (section Ai) then it takes you to the next matrix (Section Aii). Otherwise, if all answers are a no, then the survey ends
Next if you select a yes from any questions in Section Aii matrix then it takes you to the main survey of the study… Otherwise, if all answers are a no, then the survey ends.
NB: In the link provided below when a yes is selected the form is failing to proceed to another section.
visit:enketo.getodk.org/preview?form=https%3A//xlsform.getodk.org/downloads/5udw3m6y/XLS%20skip%20logic%20help.xml
Below is the XLS form in which I was using the skip logic for the grouped matrix question.
XLS FORM visit:docs.google.com/spreadsheets/d/13cyEjCtDQrssATCXLI5RSVeSRkUGSSqn/edit?usp=sharing&ouid=107168770295717395415&rtpof=true&sd=true
