Using values from previous repeat
I am new to ODK and have a basic working form (see attached XML)
I have a linear trench from which samples are collected, with From and To values. The geologists want to have a constraint which will prevent entering a From value LESS than the To value from the previous repeat.
E.g. First repeat instance
kobo_trench_logging_v2_bruce.xml (9.11 KB)
··· From: 0m To: 1.2m
Second repeat
To: 2.4m
Third repeat
All help will be appreciated.
Patrick
Dear all
I have a similar question. But want to ask about how to program this using the excel format. Any example, referral to website or manual pdf would be great help.
Best regards
Jozef
M&E Advisor Fort Portal
··· On Thursday, May 7, 2015 at 6:54:48 PM UTC+2, haza...@gmail.com wrote: > I am new to ODK and have a basic working form (see attached XML) > > I have a linear trench from which samples are collected, with From and To values. The geologists want to have a constraint which will prevent entering a From value LESS than the To value from the previous repeat. > > E.g. First repeat instance > > From: 0m > To: 1.2m > > Second repeat > > From: can only be greater or equal to 1.2m > To: 2.4m > > Third repeat > > From: can only be greater or equal to 2.4m > > All help will be appreciated. > > Thanks > Patrick
Second repeat
Third repeat
Patrick
Can anyone assist? Have looked through the indexed-repeat info, but don't understand how to reference the previous repeat.
Patrick
··· On Thursday, May 7, 2015 at 6:54:48 PM UTC+2, haza...@gmail.com wrote: > From: 0m > To: 1.2m > From: can only be greater or equal to 1.2m > To: 2.4m > From: can only be greater or equal to 2.4m
Search for "position(" on the list.
I have never tried to do this type of constraint, so I don't know if it is
possible, but it would involve that function.
If you are able to construct a form with this logic, please reply and
supply the XLSX file on this thread, as it would be a valuable contribution
for others.
To: 1.2m
Second repeat
To: 2.4m
Third repeat
Patrick
Patrick
