Using XLS Form
Hello,
My name is Shreya and I am working at CHAI. We are looking to use ODK to collect data in one of our country offices. Can you please help me with the following questions:
  1.   We have 6 different languages that the surveys will be based in - so can I have 6 different columns will the label::language in the excel so that I only have to create document that will have the option to switch between language or would you recommend creating multiple forms?
  2.   We are looking at about 150 different variables/questions - would you recommend using ODK?
  3.   We would like to code each of our responses (for all questions, but particularly multiple choice) through numbers - how exactly could we do that? This way, we can tabulate it better in STATA afterwards.
Thank a lot!
Take care,
Shreya
Hello,
– so can I have 6 different columns will the label::language in the excel
  1.   We are looking at about 150 different variables/questions –
  1.   We would like to code each of our responses (for all questions,
but particularly multiple choice) through numbers – how exactly could we do
Thank a lot!
Take care,
Shreya
Dear Shreya,
If you are planning to use STATA please do have a look at odkmeta. If you
search in the group you will find the necessary links. Its a STATA module
that proved to be invaluable for importing data from the ODK output files.
Its relatively simple to use; I've used it myself for a dataset from a 350+
question household survey of 1400 respondents. If you plan on using
multiple response questions (select multiple type) you might want to look
at the STATA modules mrdum and mrtab as well.
Warm Regards
··· On Tuesday, 22 July 2014 04:51:25 UTC+6, Shreya Agrawal wrote:
Hi Shreya,
  1. One form with label::language would be the way to go.
  2. The amount of questions is not the biggest limiting factor and 150
    sounds like an amount ODK can handle.
  3. The same way you use name and label for the questions, you also use it
    for the answers.
    For example:
name,label::english,label::portuguese
1,yes,sim
2,no,não
The values in the name column will show up in the export.
For more info on XLSForm and the syntax:
http://opendatakit.org/help/form-design/xlsform/
Good luck with the project.
best,
Olaf
··· -- olaf.veerman@flipside.org http://flipside.org On Jul 21, 2014 11:51 PM, "Shreya Agrawal" wrote:
Hello,
Thank a lot!
Take care,
Shreya
