Could any one support me on ODK Validate Errors? it said Dependency cycles amongst the xpath expressions in relevant/calculate. I uploaded my format please see and support me
Final_7.xls (100.5 KB)
Final_7.xls (103 KB)
Fixed some wrong relevance, but I also noticed that you have duplcate choice lists so if it intentional you have to add allow_choice_duplicates column in your settings sheet and below that header write yes.
I did it for now.
@aurdipas is right your fault was using a value let's say from question x10 to determine whether that question is relevant. probably it was a mistake and you wanted to do that using value from the previous question.
