verify age according to given DOB
Q1. DOB
Q2.Age
and another
Verify DOB according to given age
Q1 Age
Q2. DOB
Hi @sanish_shrestha
What value do you want to add as an answer for DOB? Only a year or maybe you need a full date? Please describe your case better.
Regards,
Grzegorz
Hi @Grzesiek2010,
when age is entered the date is automatically displayed,
and when full date is entered age is automatically displayed
sanish
so for example:
27 -> 1991
01.01.1991 -> 27
Yes @Grzesiek2010,
I want to learn in that form
yes sir my issue also same .you describe very good.How to implement your example on my form or excel sheet xlsx.
Maybe something like this: dates.xlsx (8.7 KB)
Let me know if it's satisfying for you.
Regards,
Grzegorz
i test in kobo toolbox but give error
Loading Error
Error occured during the loading of this form. It is recommended not to use this form for data entry until this is resolved.
Please contact support@kobotoolbox.org with the link to this page and the error message below:
FormLogicError: Could not evaluate: format-date(today(), ‘%Y’) - format-date( /model/instance[1]/data/dob , ‘%Y’), message: The expression is not a legal expression. (line: undefined, character: undefined)
I don't know why it doesn't work in Kobo. Everything is ok in ODK Colllect.
I also tried in Aggregate but doesn't work either.
Do you see the same error?
I tried iploading to Aggregate and works weel form me.
I got "Error: Problem with JavaRosa Parsing Form: org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: Javarosa failed to construct a FormDef. Is this an XForm definition?" this error
Now i will check and working 100% on this link thanks Grzegorz Orczykowski for help
https://odk.enke.to/preview?form=http://82.196.7.170/downloads/cepwf42m/dates.xml
Just to be sure... did you converted the form I attached to xml?
