I have my first survey that I am using a repeat group. In the table view
when I press the View button in the the table view it shows the repeated
values collected. But, in the Map view if you click on the View button
nothing happens. Any ideas?
Andy
Did you set up Google credentials? I think you now need them for the maps
visualization. http://opendatakit.org/use/aggregate/oauth2-service-account/
(for the curious, this would be the "key for browser applications" portion).
Andy
Yes I have the Google credentials. Everything else seems to work fine. Map
display, publishing to Fusion Tables, etc. Just not the View button in map
display. Mitch I still have you as an user if you want to check it out.
Andy
> visualization.
> portion).
>> Andy
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
What do you mean by the 'view' button? I don't see it in the geotagger v2
example (https://opendatakit.appspot.com).
Map display, publishing to Fusion Tables, etc. Just not the View button
in map display. Mitch I still have you as an user if you want to check it
out.
Andy
maps visualization. http://opendatakit.org/use/aggregate/oauth2-service-
account/
portion).
Andy
Groups "ODK Community" group.
mitche...@gmail.com
I do not see a repeat question in the geotagger v2 example. So there
should not be a "View" button. If you look at your Bird form there is a
repeat there and a "View" button. But since your are not collect a
geo-location you will not be able to map that form and see what I mean. I
will email you a link to our server so you can look.
Andy
>> out.
>> Andy
>>> account/
>>> portion).
>>>> view when I press the View button in the the table view it shows the
>>>> repeated values collected. But, in the Map view if you click on the View
>>>> button nothing happens. Any ideas?
>>>> Andy
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
I am also facing similar problem. Lat Long present in repeat group are not reflecting in Map It function in Visualize Tab. Can anyone suggest a solution for it. Regards
