Hello,
We just checked your page opendatakit.org for known problems and our crawler found 666 issues problems.
These are amongst others:
Alt Attribute not set
All of these pictures do not use the alt-attribute. This attribute helps Google to understand what an image is about.
Show errors
Many JavaScript Files
We found at least 5 JavaScript-files embedded within the page. You should check to see if those files can be combined to increase the speed with which the page will load.
Show errors
Duplicate Content Found
Certain content can be found on more than one URL. This is confusing to Google and often the cause for ranking problems.
Show errors
Empty Meta-Description Google may use the meta-description tag to construct the snippets that they show with your search result. By leaving this tag empty, you are giving away a powerful tool to catch a users interest in your site and increase your click-through-rate.
Show errors
You can see more errors in the free report. Just click on the button below, to view the entire report with all errors.
Show complete report for free
There are 666 issues problems waiting for you in your free report.
Best regards,
Your Optimizr-Team
I do not want to receive more e-mails
© Copyright 2014 Optimizr.com
