A coder who created a survey used a variable name "cheese" which was prompted by text and saved a string value.
Two questions later, the coder used the same variable name "cheese" which was prompted by different text and saved an integer value.
Would the integer value overwrite the string value, or would there be two "cheese" values?
I'm looking at data with two columns that have the same name "cheese" and the first is an integer and the second is blank, so i'm assuming that's what happened, but wanted to check.
For readability and maintainability, this is simply a crazy thing to do.
The answer depends upon the form design tool and the server you are using
to aggregate the results.
On ODK Aggregate, the group name qualifies the field name, so you can have
a 'patient' group with a 'name' field, and a 'practitioner' group with a
'name' field, and ODK Aggregate maintains them as separate fields.
ODK Collect works in a similar way.
However, XLSForm works only on the field names, so ${name} is ill-defined
on such a form (I don't know whether it gives an error or which one it
picks to use).
In general, it should not be possible to have two 'cheese' field names
within the same group.
"cheese" values?
