I'm making an app that users will register into it. But I want to replicate
those users (with the same credentials) to ODK Aggregate because I want
them to be able to collect data through (Enketo -> ODK Aggregate) using
the same credentials they registered in my app.
I can create the Digest Hash easily but I am afraid creating rows in ODKs *_registered_users
*and *_user_granted_authority *tables will not be enough. Should I touch
other tables as well? I did a quick test, the external user was able to
authenticate but my changes caused problems for other users so I rolled
back.
Or is there any other safer method you would suggest to try? (by calling
some ODK code or anything else, without touching tables directly).
You should be able to create rows in just those two tables and everything
should work. What was happening with the other users?
On Fri, Apr 17, 2015 at 1:50 AM, piqo wrote:
Hi there,
replicate those users (with the same credentials) to ODK Aggregate because
I want them to be able to collect data through (Enketo -> ODK Aggregate)
using the same credentials they registered in my app.
back.
The other users had issue logging in, but probably I had done some mistake.
Or perhaps it was unrelated. I rolled back pretty quickly.
I will check again.
Thanks for your answer.
piqo
> On Fri, Apr 17, 2015 at 1:50 AM, piqo <piq...@gmail.com > wrote:
>> Hi there,
>> back.
>> Ps. my app will not be in java.
>> Best,
>> piqo
>> "ODK Developers" group.
>> email to opendatakit-developers+unsubscribe@googlegroups.com
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
