In our workflow, which takes place in various countries, surveys capture timestamps, get uploaded to ODK Aggregate, and then get downloaded via ODK Briefcase. Finally, we get .csv files from ODK Briefcase. The resulting .csv files have dates in the local language and local format. I have noticed that depending on where (what country) we get the .csv files from, the date formats are slightly different, e.g. "07 Jun 15 22:27:10" vs. "Dec 4, 2014 12:45:37 PM" and "01 Agu 01" vs. "Sep 1, 1986". I am wondering where in the pipeline the conversion from a timestamp to local language happens. Does anyone know?
I know ODK Collect sends a timestamp something like "YYYY-MM-DDTHH:MM:SS.sss[[-]##]" (I might have the format slightly wrong). Is there some way to get the original timestamp sent from the phone?
Might be easier to check yourself. Check the XML from Collect first.
Then download the CSV from Aggregate and open it in a txt editor. Are
the dates the same? Now try it in Briefcase's export.
You received this message because you are subscribed to the Google Groups "ODK Developers" group.
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
The datestamp should be in the ODK Collect format up until the Export to
CSV.
Note that there are possible hour-adjustment errors in the Date processing
code
https://code.google.com/p/opendatakit/issues/detail?id=1071&q=date
https://code.google.com/p/opendatakit/issues/detail?id=1074&q=date
and perhaps other areas of the code.
The code for ODK Briefcase formatting is here:
https://github.com/opendatakit/briefcase/blob/master/src/org/opendatakit/briefcase/util/ExportToCsv.java#L345
We do whatever java.text.DateFormat.getDateInstance() does.
