Respected Everyone,
i just edited ODK Collect tool as per my own requirements, my problem is after editing everything running smoothly but when i use " Google Drive & Google Sheet Option in Server Preferences and try to download form from google drive
its shows me error as :
Unable to make API calls. if you are running a local build, please review the project readme.
someone Plz help i'm stuck here
Hi @farhann136
This is what you need to read: Google Drive and Sheets APIs
Regards,
Grzegorz
Thanks for guiding me at this point
but i've some questions plz guide me in this
1- what if i wanna use default Google API instead of registering new project in Google Console.
i don't wanna edit any setting in API
i just wanna edit the look of App for my own purpose
Plz guide me as i am new in APK editing
Regards,
It's required. If you want to build your own app based on the original code you have to do that even if you don't change anything.
Regards,
Grzegorz
