I am facing encryption problem in odk collect. i was follow form encryption
steps from https://opendatakit.org/help/encrypted-forms/ . As per document
form was created successfully and taken a survey with this form(where mark
it as completed). After completed all process i had taken xform and data
xml into my computer, but, i can simply open and view my xform. i have
attached my xform and data xml in here. Please help me with some
information.
Those two files look like a form definition (which I don't think ODK ever
encrypts) and a signature for the encrypted data. There should be another
file, ending in '.enc', that has the encrypted data in it.
On Sunday, 7 February 2016 19:46:35 UTC+13, AndroidCuet wrote:
> Dear all,
> encryption steps from https://opendatakit.org/help/encrypted-forms/ . As
> per document form was created successfully and taken a survey with this
> form(where mark it as completed). After completed all process i had taken
> xform and data xml into my computer, but, i can simply open and view my
> xform. i have attached my xform and data xml in here. Please help me with
> some information.
> Thank You
Thank You so much @Thomas Graydon-Guy and Mitch Sundt for your helpful
response.
On Sunday, February 7, 2016 at 12:46:35 PM UTC+6, AndroidCuet wrote:
> Dear all,
> some information.
> Thank You
Correct. The form definition is never encrypted. Only the submissions --
and submissions are not encrypted on the device until you "Mark form as
Finalized" your submission. Until then, the data is stored in plain text
on your device.
The submissions are under /sdcard/odk/instances/
On Tue, Feb 9, 2016 at 1:30 PM, Thomas Graydon-Guy < t.graydon-guy@massey.ac.nz> wrote:
Dear all,
some information.
