I am creating an XForm to collect some data. I am using pretty straight-forward concepts, and the most complex of them is pulldata(). However, I am meeting a problem validating it because I keep getting this error:
There has been a problem trying to replace ${name} with the XPath to the survey element named 'name'. There is no survey element with this name.
I have double-checked and I have no survey element called ${name} at all, except as the name of the column I need to grab from the dataset with pulldata().
I am using Google Sheets to create this, and validating it on Ona. I have also tried to validate it at xlsform/v1/.
I have checked the form over and over to see what the problem is, and it still doesn't work.
I have attached all 2 forms (XForm and dataset) plus the error message I keep getting.
boda pricing survey (2).xlsx (191.7 KB) drivers.csv (13.2 KB)
