Is there any free, easy way to convert xls to xml offline?
Thank you,
Thank you,
And there are other XLSForm converters available -- see the list here:
http://opendatakit.org/use/xlsform/
Thank you,
Hi Suzanne,
What's the old joke about software? Your options are fast, easy, and
free. Choose two.
Nafundi's XLSForm Offline app works on Windows and Macs, validates the
form, and is regularly updated. Our users report that it is fast and
very easy to use.
Try XLSForm for Windows, and if that doesn't work for you, give
XLSForm Offline a go. You can find it at
https://gumroad.com/l/xlsform-offline.
On Wed, Sep 3, 2014 at 8:24 AM, Mitch Sundt mitchellsundt@gmail.com wrote:
http://opendatakit.org/downloads/download-info/xlsform-for-windows/
http://opendatakit.org/use/xlsform/On Wed, Sep 3, 2014 at 1:36 AM, suzanne.fuhrman@gmail.com wrote:
Thank you,
mitchellsundt@gmail.com--
i tried to get xlsform.exe, but i think the link you give for xlsform.exe doesnt work (http://opendatakit.org/downloads/download-info/xlsform-for-windows/). It tells me file is not downloadable because infected by a virus. Should i report this somewhere?
The download link is correct.
Perhaps your virus scanning software needs an update? Or you are accessing
the files from a non-secure location?
Some of the Google downloads will warn that the file is too large for
Google to scan for viruses -- see attached. This is expected.
doesnt work (
report this somewhere?--
