Hey everyone,
I put together a windows executable for converting XLSForms locally.
For usage instructions and a download link see the readme here:
https://github.com/nathanathan/xlsform.exe/blob/master/README.md
I've only tested this on my own machine so far, so let me know if you
run into any problems.
Regards,
-Nathan
On Monday, November 26, 2012 1:57:35 AM UTC-8, Bashir Jahed wrote:Would
be great to have this functionality. any way we can get a how to to also be
able to use this facility?
On Sunday, 25 November 2012 07:47:09 UTC+2, Stuart Shirrell
wrote:Thanks, Nathan. I've got XLSForm running offline now. No need to
worry about low bandwidth anymore!
-Stuart
On Sun, Nov 25, 2012 at 2:22 AM, Nathan nab...@gmail.com wrote:
The source code is available here.
I'm hoping I can package the whole thing with py2exe so it
isn't necessary to install python and xlrd.
Regards,
-Nathan
On Saturday, November 24, 2012 5:36:22 AM UTC-8, Stuart Shirrell wrote:
An offline version of XLSForm version would be immensely helpful for me,
as I'm often working in low-bandwidth environments and with relatively
large forms (our XML files are approximately 1MB, which takes a few minutes
to download, making working bugs out of the forms slow). Let me know if
you can do this, or if you just want to send the source code, I can
probably make it work myself.
Stuart
On Sat, Nov 24, 2012 at 9:47 AM, Nathan nab...@gmail.com wrote:
Hi Stuart,
There shouldn't be any downtime, however the converter is running off a
single AWS micro-instance, so there's no fail over, and I have no idea how
well it deals with multiple concurrent users. I'm thinking about adding a
link to a backup instance or trying to create a downloadable
exe for occasions when the main XLSForm converter isn't available.
Regards,
-Nathan
On Thursday, November 22, 2012 8:03:04 PM UTC-8, Stuart Shirrell wrote:
Hi Nathan,
Thanks for the quick reply.
The converter's working for me now, but I was having some issues with it
on Thursday evening India time. For the past few days, I've been trying to
make changes to some of our surveys around 5pm-8pm IST (6:30am-9:30am EST).
While the form submission page will load, I've either been getting a 500
server error whenever I try to post forms. The problem seems to resolve
later in the evening India time. Is the server offline for some specified
period of time?
My OS is OSX 10.7.4, and I'm running Chrome v23.
Thanks so much,
Stuart
On Fri, Nov 23, 2012 at 8:24 AM, Nathan nab...@gmail.com wrote:
Hi Stuart,
The XLSForm converter is working for me. Where are you running into
problems? For instance, does the file chooser appear? If so, do you get
any response back after clicking submit?
If you're still having trouble getting it to work, could you send me the
form you are trying to convert and also tell me which browser/OS you are
using so I can attempt to reproduce the problem.
Regards,
-Nathan
On Thursday, November 22, 2012 5:39:41 AM UTC-8, Stuart Shirrell wrote:
Is the XLSForm converter server offline? It's been acting up for a few
days. I desperately need it to work, as our surveys rely heavily on
cascading selects, which formhub won't convert.
Any information on this ASAP would be much appreciated.
-Stuart
Stuart Shirrell
IDinsight | Data. Decisions. Development
India: +91 97-71-402293
US: +1 (817) 203-4022
www.IDinsight.org
Stuart Shirrell
www.IDinsight.org
Stuart Shirrell
www.IDinsight.org
