Hi everyone.
As posted here (https://github.com/opendatakit/xlsform-offline/issues/37) I got into an issue using xlsform-offline 1.5.0 version: max-pixels not translated into the xml file.
You can try here a simple xls file, with an image reduced with the parameter.
thank you very much!
Thank you so much for this!
v1.5.0 is pretty old, we added support for max-pixels
in v1.7.0 https://github.com/opendatakit/xlsform-offline/releases/tag/v1.7.0 why do you use such an old version? The newest one is v1.11.1
Ok ok perfect..i thought the 1.5 was the latest sorry
yes, all correct, last version is producing the correct max-pixels.... so, false alarm, sorry. Thank for you help.
Angelo
