When I try to validate/convert my .xls form I get the following error
[Errno 28] No space left on device: '/tmp/tmp_www-data/tmp4rPV67'
Request Method: POST
Request URL: http://23.21.114.69/xlsform/
Django Version: 1.8.4
Exception Type: OSError
Exception Value:
[Errno 28] No space left on device: '/tmp/tmp_www-data/tmpjVAbuO'
Exception Location: /usr/lib/python2.7/tempfile.py in mkdtemp, line 333
Python Executable: /usr/bin/python
Python Version: 2.7.6
Python Path:
['/home/ubuntu/django/xlsform',
'/home/ubuntu/django/xlsform/xlsform/pyxform_interface/src/pyxform',
'/usr/local/lib/python2.7/dist-packages/setuptools-18.3.2-py2.7.egg',
'/usr/lib/python2.7',
'/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/home/ubuntu/django/xlsform/xlsform']
Server time: Wed, 30 Mar 2016 09:26:42 +0000
Any ideas on how to fix this ?
It looks there's an issue with the server hosting the web application and the /tmp or /tmp/tmp_www-data volume has run out of space. I guess the System Administrator will need to fix it to bring it back to normality.
I'm having the same issue:
OSError at /
[Errno 28] No space left on device: '/tmp/tmp_www-data/tmpLtaK6F'
Exception Value:
Regards,
> Request Method:POSTRequest URL:http://23.21.114.69/xlsform/Django Version:1.8.4Exception Type:OSErrorException Value:[Errno 28] No space left on device: '/tmp/tmp_www-data/tmpjVAbuO'Exception Location:/usr/lib/python2.7/tempfile.py in mkdtemp, line 333Python Executable:/usr/bin/pythonPython Version:2.7.6Python Path:['/home/ubuntu/django/xlsform',
> '/home/ubuntu/django/xlsform/xlsform']Server time:Wed, 30 Mar 2016 09:26:42 +0000
> Thanks
Hi Roly,
The core team is responsible for that tool and I'm sure they'll take a look
when they wake up.
Until then, as it says on the page, try the offline converters at
https://opendatakit.org/use/xlsform.
Need ODK consultants? Nafundi provides form design, server setup, in-field
training, and software development for ODK. Go to https://nafundi.com to
get started.
On Wed, Mar 30, 2016 at 11:26 AM, roly lautenbach <lautenbach.roly@gmail.com wrote:
Exception Value:
Python Path:
This has been resolved.
I also adjusted the file-removal interval to reduce the likelihood of the
disk getting full.
09:26:42 +0000
OSError at /
Exception Value:
Regards,
Thanks for your prompt reply - will do.
Regards
Roland Lautenbach
082 658 1000
On 30 March 2016 at 15:14, Yaw Anokwa wrote:
Hi Roly,
look when they wake up.
get started.
On Wed, Mar 30, 2016 at 11:26 AM, roly lautenbach < lautenbach.roly@gmail.com> wrote:
Exception Value:
Python Path:
https://groups.google.com/d/topic/opendatakit/QVAO6Je__o0/unsubscribe.
the problem is back again can you please check the server again.
thanks,
Ibrahim
> disk getting full.
>> 09:26:42 +0000
>> > Thanks
>> Hi,
>> OSError at /
>> Exception Value:
>> Regards,
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
