XML Form upload problem
Can anybody help me as I am not able to upload my XML form to the server.
in Tomcat log this type of error coming continuously:
WARNING: Create failed -- assuming phantom table required odk_prod.TIRAH_V_F_CORE
Apr 15, 2013 8:11:03 AM org.opendatakit.common.persistence.engine.mysql.DatastoreImpl dropRelation
INFO: Executing DROP TABLE odk_prod.TIRAH_V_F_CORE by user uid:bilal.manzoor@gmail.commailto:uid%3Abilal.manzoor@gmail.com|2012-08-08T06:22:37.378+0000
check if you can get any support from odk on above error. or how we can purge or reconfigure fresh database for odk.
What version of ODK Aggregate are you using?
If you upgraded from an earlier ODK Aggregate version, did you follow the
upgrade steps outlined in
http://code.google.com/p/opendatakit/wiki/AggregateReleaseNotes
Does the form validate successfully using ODK Validate?
http://code.google.com/p/opendatakit/downloads/detail?name=ODK%20Validate%201.3%20for%20ODK%20Collect%20v1.3%20and%20v1.2.jar
If it validates OK, can you send it to me ( mitchellsundt@gmail.com ) and I
will look at it tomorrow.
server.****
in Tomcat log this type of error coming continuously:****
*Apr 15, 2013 8:11:03 AM
uid:bilal.manzoor@gmail.com|2012-08-08T06:22:37.378+0000
purge or reconfigure fresh database for odk.****
"ODK Developers" group.
