Hello everyone,
I have 3 questions:
Regarding scripting the survey using the XML format, is there any
reference to learn how to write the survey on XML format?
Where to find a guide to apply some changes in the appearance column in
the XLS form?
Is it allowed to merge two/more questions in one screen? If yes, How?
Looking forward to hearing from you.
All the Best,
Ali Helmi
Hi, Ali.
Please, see answers to all your questions (and more), at
http://xlsform.org/.
Regards,
Le jeudi 18 mai 2017 23:22:26 UTC+2, Ali Helmi a écrit :
> Hello everyone,
> I have 3 questions:
> 1. Regarding scripting the survey using the XML format, is there any
> 2. Where to find a guide to apply some changes in the appearance column in
> the XLS form?
> 3. Is it allowed to merge two/more questions in one screen? If yes, How?
> All the Best,
> Ali Helmi
Ali,
for your first question, I think that the easiest way is to convert xlsfrm
into xml form, using this converter https://gumroad.com/l/xlsform-offline
but, you can also look at this guide
https://opendatakit.org/help/form-design/
> Hello everyone,
> I have 3 questions:
> the XLS form?
> All the Best,
> Ali Helmi
