Hello. I am new to ODK. I am currently working on a school project
to create an Android app. We are exploring using ODK Collect to
create our user forms, retrieve user data, and store it on an ODK
server. Prior to exploring this idea, my fellow group members and I
had created several UI layouts using Eclipse with the Android plugin
within an Android project. Are these XML layouts generated by Eclipse
usable with ODK.
you can take these xml layouts and build android activities or views
around them.
you can then either load these applications from a button press (like
barcode scanning) or load the views inline (like the select multiple
widget). depending on how you've structured your layouts these could
be simple or hard. we are working on an api to make this much easier
but no promises on when that'd be done.
i'm glad to take a look at the layouts but given that would be pretty
technical, you should use http://dpaste.com to host the xml and send a
message to opendatakit-developers@googlegroups.com and we can continue
the discussion there.
> usable with ODK.
> Thanks for your help.
