Hi all
How do I convert an xml form to odkbuild format or import it into aggregate.
My process was to create the form in odkbuild, then save as xml then
edit and try to upload....
Help!
Chris Buddenhagen
Hi all
Help!
Chris Buddenhagen
A properly formatted XML form should be able to be uploaded to
Aggregate. Try using ODK Validate to determine what the problem with
the XML form is. Build has two options to get forms into Aggregate
"Export to Aggregate" which puts the form directly into a 0.9.x series
Aggregate and "Export to XML" which you should be able to take the XML
output and upload into Aggregate.
Waylon
