Hi. I'm trying to get XLSForm generated xforms to display in XSLTForms
on a browser, but it seems as if the syntax is different?
I can change the XForm to display in one, but not the other. For
example, repeat does not work the same in both. In XSLTForm it
requires a trigger, and this makes ODK Validate unhappy. Also many
binds in ODK do not exist for XSLTForms
Yes, the flavor of XForms supported by javarosa is non-standard and it is
unlikely you'll be able to get this to work in a formal XForms renderer.
Some of the binds, e.g., barcode, geopoint, are clearly not going to work.
If you keep to simple types that don't require accessing specialized
hardware or external programs, you'll probably be OK.
I would be happy to upgrade XSLTForms so it could also be used with
XLSForm generated xforms.
Specific features such as barcode can be added in XSLTForms and, as a
W3C Forms Working Group member, I could even propose them to be added
in future XForms specifications.
Could you please me some test cases?
Thanks!
-Alain
> Am I doing something wrong?
> Thanks,
> Thanks!
> -Alain
>> Thanks,
If certain XForms constructs need to be ignored or allowed, the parser for
this engine should be updated so that XLSForm can generate constructs that
work within a standard browser.
On Fri, Jun 8, 2012 at 10:31 AM, W. Brunette wrote:
Our sandbox site for users to play with have many JavaRosa Xforms with
the extra features such as barcode. opendatakit.appspot.com
