2 errors SAIA cell phone
Dear ODK,
I am emailing you from Mozambique and we are encountering 2 new errors on ODK that we have been unable to fix (we usually are able
to fix any errors we encounter without much trouble). Therefore, we are requesting your assistance. Attached is a screen shot of the
2 error messages we are receiving. Would you be able to review these errors and possibly provide any recommendations?
Thank you very much,
Jason
Hi Jason,
Is this a stock version of ODK Collect? If so, what version and build
number? When does this error occur? Is it reproducible on other
devices or just this one? How do you reproduce it?
On Tue, Sep 8, 2015 at 4:09 AM, bestej@u.washington.edu wrote:
Dear ODK,
ODK that we have been unable to fix (we usually are able to fix any errors
Jason
Power cycle your device.
If you get any complaint about the BasicClientConnManager it should be
cleared up by a reboot of the device.
If you have time, capturing a logcat of the issue would help us fix it.
··· On Tue, Sep 8, 2015 at 10:50 AM, Yaw Anokwa wrote:
Hi Jason,
Dear ODK,
errors
errors
Jason
