I need to setup ODK Aggregate for testing purposes with another tool locally. I followed the steps described here: https://docs.opendatakit.org/aggregate-tomcat But when navigation to http://localhost:8080/ODKAggregate I get a 404 error.
Tomcat Version 9.0.14
ODK Aggregate v1.7.1
Mysql Server v5.7.23
OS Mac OS Mojave
From the apache log
WARNING: Failure: _granted_authority_hierarchy exception: org.springframework.transaction.CannotCreateTransactionException: Could not open JDBC Connection for transaction; nested exception is java.sql.SQLException: Cannot create PoolableConnectionFactory (Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.)
Dez. 14, 2018 3:46:02 NACHM. org.opendatakit.common.security.spring.RoleHierarchyImpl refreshReachableGrantedAuthorities
WARNING: Datastore failure: refreshReachableGrantedAuthorities -- adjusting retry time
Dez. 14, 2018 3:46:02 NACHM. org.springframework.context.support.AbstractApplicationContext refresh
WARNING: Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'hierarchicalRoleRelationships' defined in ServletContext resource [/WEB-INF/applicationContext-security.xml]: Invocation of init method failed; nested exception is org.opendatakit.common.persistence.exception.ODKDatastoreException: org.springframework.transaction.CannotCreateTransactionException: Could not open JDBC Connection for transaction; nested exception is java.sql.SQLException: Cannot create PoolableConnectionFactory (Communications link failure
Thanks for your help. If any additional information is needed just tell me.
