I wonder if you have experience using “ ../field “ ? I don’t quite
understand the difference between ../ versus ${}, but it seems that I have
to change a few referencing from ${field} to ../field in some repeat
groups of my form, otherwise the second repeat group will crash. I couldn't
find a common rule of what exact situation that I have to do ../ .
The ../node or /path/to/node "XPath" syntax is what ODK Collect and Enketo
actually use internally (they render XForms not XLSForms). The relative
path "../node" means that from the current field you go one step back and
find a field with the name "node". You can read more about the actual XForm
format that is supported here: http://opendatakit.github.io/odk-xform-spec/.
Even for die-hard XML and XPath enthusiasts (if they exist), coding an
XForm by hand is very tedious. That's why we are lucky to have XLSForms,
that will translate and easy-to-build XLSForm into an XForm. One of the
shortcuts is the ${field} syntax which currently always translates to an
absolute "/path/to/field" (though XLSForm also supports the XPath syntax).
At some point, a long time ago, a rather unfortunate error was made with how
repeats should be handled http://opendatakit.github.io/odk-xform-spec/#a-big-deviation-with-xforms.
We are working around this in ODK Collect and Enketo, but you are probably
dealing with an artefact of this issue, and found a way to resolve it by
using the correct relative XPath syntax instead of the ${field} shortcut
when referring to fields inside a repeat.
If you are referring to a field that is at the same level as the field
where you are referring from you'd use "../field" instead of ${field}. If
you are inside a group and are referring to a field just outside that
group, you could use "../../field" instead of ${field}. Etcetera.
Cheers,
Martijn
On Tuesday, April 21, 2015 at 1:27:21 PM UTC-6, Eva Q wrote:
> Hi there,
> On ODK Binding, it has the descriptions of the two here
> *https://opendatakit.org/help/form-design/binding/*
> but I don’t quite get
> it. Could anyone please clarify this please?
> Thank you very much.
> E
