A slider widget for selecting a value from a range
Hi there
Is there a slider widget for selecting a value from a range in ODK?
Regards
JDChinga
Not at this time. The examples of all the available widgets are here:
If someone writes a widget and contributes it back to the project under an
Apache 2 license, we will add it to the main codebase.
ยทยทยท On Thu, Oct 10, 2013 at 3:07 AM, Jeffrey Dirawo wrote:
Hi there
Regards
JDChinga
We have a slider widget that will be checked into trunk soon. Check
for updates at https://code.google.com/p/opendatakit/issues/detail?id=136.
ยทยทยท --- Need ODK services? http://nafundi.com provides form design, professional support, custom reporting, and software development for ODK.
http://opendatakit.org/help/form-design/examples/
On Thu, Oct 10, 2013 at 3:07 AM, Jeffrey Dirawo jdchinga@gmail.com wrote:
Hi there
Regards
JDChinga
Hi Yaw,
Has the slide widget ever made available yet? Does it work with ODK Collect?
Ben
ยทยทยท On Thursday, October 10, 2013 1:00:21 PM UTC-4, Yaw Anokwa wrote: > We have a slider widget that will be checked into trunk soon. Check > > for updates at https://code.google.com/p/opendatakit/issues/detail?id=136. > > > > Yaw > > --- > > Need ODK services? http://nafundi.com provides form design, > > professional support, custom reporting, and software development for > > ODK. > > > > On Thu, Oct 10, 2013 at 9:51 AM, Mitch Sundt wrote: > > > Not at this time. The examples of all the available widgets are here: > > > http://opendatakit.org/help/form-design/examples/ > > > > > > If someone writes a widget and contributes it back to the project under an > > > Apache 2 license, we will add it to the main codebase. > > > > > > > > > On Thu, Oct 10, 2013 at 3:07 AM, Jeffrey Dirawo wrote: > > >> > > >> Hi there > > >> > > >> Is there a slider widget for selecting a value from a range in ODK? > > >> > > >> Regards > > >> > > >> JDChinga > > >> > > >> -- > > >> -- > > >> Post: opendatakit@googlegroups.com > > >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com > > >> Options: http://groups.google.com/group/opendatakit?hl=en > > >> > > >> --- > > >> You received this message because you are subscribed to the Google Groups > > >> "ODK Community" group. > > >> To unsubscribe from this group and stop receiving emails from it, send an > > >> email to opendatakit+unsubscribe@googlegroups.com. > > >> For more options, visit https://groups.google.com/groups/opt_out. > > > > > > > > > > > > > > > -- > > > Mitch Sundt > > > Software Engineer > > > University of Washington > > > > > > > > > -- > > > -- > > > Post: opendatakit@googlegroups.com > > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > > > --- > > > You received this message because you are subscribed to the Google Groups > > > "ODK Community" group. > > > To unsubscribe from this group and stop receiving emails from it, send an > > > email to opendatakit+unsubscribe@googlegroups.com. > > > For more options, visit https://groups.google.com/groups/opt_out.
Hey. I thought this was possible in ODK Survey?
Neil, where did you grab the slider when you were customizing the slider
for Oxfam?
ยทยทยท On Fri, Apr 18, 2014 at 2:13 PM, wrote:
Hi Yaw,
Collect?
Ben
for updates at
ODK.
under an
Hi there
Regards
JDChinga
Groups
send an
Groups
an
Ben,
Never got a chance to add the slider to trunk. It's on our list, but
it's pretty low priority.
Agreed with Jitka, that it is probably possible in ODK Survey.
ยทยทยท -- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.
Neil, where did you grab the slider when you were customizing the slider for
Oxfam?
On Fri, Apr 18, 2014 at 2:13 PM, bbaumann@openclinica.com wrote:
Hi Yaw,
Collect?
Ben
for updates at
ODK.
under an
Hi there
Regards
JDChinga
Groups
send an
Groups
an
Hi Yaw!
Have you been able to code the slider? would it be possible to have access to the code if you have it available?
Isabel
ยทยทยท El martes, 22 de abril de 2014, 19:21:14 (UTC+2), Yaw Anokwa escribiรณ: > Ben, > > Never got a chance to add the slider to trunk. It's on our list, but > it's pretty low priority. > > Agreed with Jitka, that it is probably possible in ODK Survey. > > Yaw > -- > Need ODK services? http://nafundi.com provides form design, server > setup, professional support, and software development for ODK. > > On Fri, Apr 18, 2014 at 2:39 PM, Jitka Hiscox wrote: > > Hey. I thought this was possible in ODK Survey? > > > > Neil, where did you grab the slider when you were customizing the slider for > > Oxfam? > > > > > > On Fri, Apr 18, 2014 at 2:13 PM, wrote: > >> > >> Hi Yaw, > >> > >> Has the slide widget ever made available yet? Does it work with ODK > >> Collect? > >> > >> Thanks, > >> Ben > >> > >> > >> On Thursday, October 10, 2013 1:00:21 PM UTC-4, Yaw Anokwa wrote: > >> > We have a slider widget that will be checked into trunk soon. Check > >> > > >> > for updates at > >> > https://code.google.com/p/opendatakit/issues/detail?id=136. > >> > > >> > > >> > > >> > Yaw > >> > > >> > --- > >> > > >> > Need ODK services? http://nafundi.com provides form design, > >> > > >> > professional support, custom reporting, and software development for > >> > > >> > ODK. > >> > > >> > > >> > > >> > On Thu, Oct 10, 2013 at 9:51 AM, Mitch Sundt wrote: > >> > > >> > > Not at this time. The examples of all the available widgets are here: > >> > > >> > > http://opendatakit.org/help/form-design/examples/ > >> > > >> > > > >> > > >> > > If someone writes a widget and contributes it back to the project > >> > > under an > >> > > >> > > Apache 2 license, we will add it to the main codebase. > >> > > >> > > > >> > > >> > > > >> > > >> > > On Thu, Oct 10, 2013 at 3:07 AM, Jeffrey Dirawo wrote: > >> > > >> > >> > >> > > >> > >> Hi there > >> > > >> > >> > >> > > >> > >> Is there a slider widget for selecting a value from a range in ODK? > >> > > >> > >> > >> > > >> > >> Regards > >> > > >> > >> > >> > > >> > >> JDChinga > >> > > >> > >> > >> > > >> > >> -- > >> > > >> > >> -- > >> > > >> > >> Post: opendatakit@googlegroups.com > >> > > >> > >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com > >> > > >> > >> Options: http://groups.google.com/group/opendatakit?hl=en > >> > > >> > >> > >> > > >> > >> --- > >> > > >> > >> You received this message because you are subscribed to the Google > >> > >> Groups > >> > > >> > >> "ODK Community" group. > >> > > >> > >> To unsubscribe from this group and stop receiving emails from it, > >> > >> send an > >> > > >> > >> email to opendatakit+unsubscribe@googlegroups.com. > >> > > >> > >> For more options, visit https://groups.google.com/groups/opt_out. > >> > > >> > > > >> > > >> > > > >> > > >> > > > >> > > >> > > > >> > > >> > > -- > >> > > >> > > Mitch Sundt > >> > > >> > > Software Engineer > >> > > >> > > University of Washington > >> > > >> > > > >> > > >> > > > >> > > >> > > -- > >> > > >> > > -- > >> > > >> > > Post: opendatakit@googlegroups.com > >> > > >> > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > >> > > >> > > Options: http://groups.google.com/group/opendatakit?hl=en > >> > > >> > > > >> > > >> > > --- > >> > > >> > > You received this message because you are subscribed to the Google > >> > > Groups > >> > > >> > > "ODK Community" group. > >> > > >> > > To unsubscribe from this group and stop receiving emails from it, send > >> > > an > >> > > >> > > email to opendatakit+unsubscribe@googlegroups.com. > >> > > >> > > For more options, visit https://groups.google.com/groups/opt_out. > >> > >> -- > >> -- > >> Post: opendatakit@googlegroups.com > >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com > >> Options: http://groups.google.com/group/opendatakit?hl=en > >> > >> --- > >> You received this message because you are subscribed to the Google Groups > >> "ODK Community" group. > >> To unsubscribe from this group and stop receiving emails from it, send an > >> email to opendatakit+unsubscribe@googlegroups.com. > >> For more options, visit https://groups.google.com/d/optout. > > > > > > -- > > -- > > Post: opendatakit@googlegroups.com > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > --- > > You received this message because you are subscribed to the Google Groups > > "ODK Community" group. > > To unsubscribe from this group and stop receiving emails from it, send an > > email to opendatakit+unsubscribe@googlegroups.com. > > For more options, visit https://groups.google.com/d/optout.
Isabel,
No, and no ETA. Sorry.
ยทยทยท On Mon, Feb 16, 2015 at 12:01 PM, wrote: > Hi Yaw! > > Have you been able to code the slider? would it be possible to have access to the code if you have it available? > > Best, > > Isabel > > > El martes, 22 de abril de 2014, 19:21:14 (UTC+2), Yaw Anokwa escribiรณ: >> Ben, >> >> Never got a chance to add the slider to trunk. It's on our list, but >> it's pretty low priority. >> >> Agreed with Jitka, that it is probably possible in ODK Survey. >> >> Yaw >> -- >> Need ODK services? http://nafundi.com provides form design, server >> setup, professional support, and software development for ODK. >> >> On Fri, Apr 18, 2014 at 2:39 PM, Jitka Hiscox wrote: >> > Hey. I thought this was possible in ODK Survey? >> > >> > Neil, where did you grab the slider when you were customizing the slider for >> > Oxfam? >> > >> > >> > On Fri, Apr 18, 2014 at 2:13 PM, wrote: >> >> >> >> Hi Yaw, >> >> >> >> Has the slide widget ever made available yet? Does it work with ODK >> >> Collect? >> >> >> >> Thanks, >> >> Ben >> >> >> >> >> >> On Thursday, October 10, 2013 1:00:21 PM UTC-4, Yaw Anokwa wrote: >> >> > We have a slider widget that will be checked into trunk soon. Check >> >> > >> >> > for updates at >> >> > https://code.google.com/p/opendatakit/issues/detail?id=136. >> >> > >> >> > >> >> > >> >> > Yaw >> >> > >> >> > --- >> >> > >> >> > Need ODK services? http://nafundi.com provides form design, >> >> > >> >> > professional support, custom reporting, and software development for >> >> > >> >> > ODK. >> >> > >> >> > >> >> > >> >> > On Thu, Oct 10, 2013 at 9:51 AM, Mitch Sundt wrote: >> >> > >> >> > > Not at this time. The examples of all the available widgets are here: >> >> > >> >> > > http://opendatakit.org/help/form-design/examples/ >> >> > >> >> > > >> >> > >> >> > > If someone writes a widget and contributes it back to the project >> >> > > under an >> >> > >> >> > > Apache 2 license, we will add it to the main codebase. >> >> > >> >> > > >> >> > >> >> > > >> >> > >> >> > > On Thu, Oct 10, 2013 at 3:07 AM, Jeffrey Dirawo wrote: >> >> > >> >> > >> >> >> > >> >> > >> Hi there >> >> > >> >> > >> >> >> > >> >> > >> Is there a slider widget for selecting a value from a range in ODK? >> >> > >> >> > >> >> >> > >> >> > >> Regards >> >> > >> >> > >> >> >> > >> >> > >> JDChinga >> >> > >> >> > >> >> >> > >> >> > >> -- >> >> > >> >> > >> -- >> >> > >> >> > >> Post: opendatakit@googlegroups.com >> >> > >> >> > >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> > >> >> > >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> > >> >> > >> >> >> > >> >> > >> --- >> >> > >> >> > >> You received this message because you are subscribed to the Google >> >> > >> Groups >> >> > >> >> > >> "ODK Community" group. >> >> > >> >> > >> To unsubscribe from this group and stop receiving emails from it, >> >> > >> send an >> >> > >> >> > >> email to opendatakit+unsubscribe@googlegroups.com. >> >> > >> >> > >> For more options, visit https://groups.google.com/groups/opt_out. >> >> > >> >> > > >> >> > >> >> > > >> >> > >> >> > > >> >> > >> >> > > >> >> > >> >> > > -- >> >> > >> >> > > Mitch Sundt >> >> > >> >> > > Software Engineer >> >> > >> >> > > University of Washington >> >> > >> >> > > >> >> > >> >> > > >> >> > >> >> > > -- >> >> > >> >> > > -- >> >> > >> >> > > Post: opendatakit@googlegroups.com >> >> > >> >> > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> > >> >> > > Options: http://groups.google.com/group/opendatakit?hl=en >> >> > >> >> > > >> >> > >> >> > > --- >> >> > >> >> > > You received this message because you are subscribed to the Google >> >> > > Groups >> >> > >> >> > > "ODK Community" group. >> >> > >> >> > > To unsubscribe from this group and stop receiving emails from it, send >> >> > > an >> >> > >> >> > > email to opendatakit+unsubscribe@googlegroups.com. >> >> > >> >> > > For more options, visit https://groups.google.com/groups/opt_out. >> >> >> >> -- >> >> -- >> >> Post: opendatakit@googlegroups.com >> >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> >> >> --- >> >> You received this message because you are subscribed to the Google Groups >> >> "ODK Community" group. >> >> To unsubscribe from this group and stop receiving emails from it, send an >> >> email to opendatakit+unsubscribe@googlegroups.com. >> >> For more options, visit https://groups.google.com/d/optout. >> > >> > >> > -- >> > -- >> > Post: opendatakit@googlegroups.com >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> > Options: http://groups.google.com/group/opendatakit?hl=en >> > >> > --- >> > You received this message because you are subscribed to the Google Groups >> > "ODK Community" group. >> > To unsubscribe from this group and stop receiving emails from it, send an >> > email to opendatakit+unsubscribe@googlegroups.com. >> > For more options, visit https://groups.google.com/d/optout. > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to the Google Groups "ODK Community" group. > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
Dear Yaw,
Many thanks for your prompt reply! I am needing the slider for a project
and I dont know how to program it myself. Do you know what would be the
specifications for outsourcing the programming of the slider and how much
one would probably have to pay somebody for the programming (on an internet
platform)?
Thanks a lot!
Isabel Santana
ยทยทยท On Tue, Feb 17, 2015 at 1:14 AM, Yaw Anokwa wrote:
Isabel,
On Mon, Feb 16, 2015 at 12:01 PM, maisabel.santana@gmail.com wrote:
Hi Yaw!
Isabel
Ben,
slider for
Oxfam?
Hi Yaw,
Collect?
Ben
for updates at
for
ODK.
On Thu, Oct 10, 2013 at 9:51 AM, Mitch Sundt < mitchellsundt@gmail.com> wrote:
here:
under an
Hi there
ODK?
Regards
JDChinga
Google
Groups
it,
send an
Google
Groups
it, send
an
Groups
send an
Groups
send an
https://groups.google.com/d/topic/opendatakit/T2lwpswAIx0/unsubscribe.
Isabel,
Your best bet is to find one of the companies at
https://opendatakit.org/help/help-for-hire.
ยทยทยท On Tue, Feb 17, 2015 at 2:28 AM, Ma Isabel Santana wrote: > Dear Yaw, > > Many thanks for your prompt reply! I am needing the slider for a project and > I dont know how to program it myself. Do you know what would be the > specifications for outsourcing the programming of the slider and how much > one would probably have to pay somebody for the programming (on an internet > platform)? > > Thanks a lot! > > Best, > > Isabel Santana > > On Tue, Feb 17, 2015 at 1:14 AM, Yaw Anokwa wrote: >> >> Isabel, >> >> No, and no ETA. Sorry. >> >> Yaw >> >> On Mon, Feb 16, 2015 at 12:01 PM, wrote: >> > Hi Yaw! >> > >> > Have you been able to code the slider? would it be possible to have >> > access to the code if you have it available? >> > >> > Best, >> > >> > Isabel >> > >> > >> > El martes, 22 de abril de 2014, 19:21:14 (UTC+2), Yaw Anokwa escribiรณ: >> >> Ben, >> >> >> >> Never got a chance to add the slider to trunk. It's on our list, but >> >> it's pretty low priority. >> >> >> >> Agreed with Jitka, that it is probably possible in ODK Survey. >> >> >> >> Yaw >> >> -- >> >> Need ODK services? http://nafundi.com provides form design, server >> >> setup, professional support, and software development for ODK. >> >> >> >> On Fri, Apr 18, 2014 at 2:39 PM, Jitka Hiscox wrote: >> >> > Hey. I thought this was possible in ODK Survey? >> >> > >> >> > Neil, where did you grab the slider when you were customizing the >> >> > slider for >> >> > Oxfam? >> >> > >> >> > >> >> > On Fri, Apr 18, 2014 at 2:13 PM, wrote: >> >> >> >> >> >> Hi Yaw, >> >> >> >> >> >> Has the slide widget ever made available yet? Does it work with ODK >> >> >> Collect? >> >> >> >> >> >> Thanks, >> >> >> Ben >> >> >> >> >> >> >> >> >> On Thursday, October 10, 2013 1:00:21 PM UTC-4, Yaw Anokwa wrote: >> >> >> > We have a slider widget that will be checked into trunk soon. >> >> >> > Check >> >> >> > >> >> >> > for updates at >> >> >> > https://code.google.com/p/opendatakit/issues/detail?id=136. >> >> >> > >> >> >> > >> >> >> > >> >> >> > Yaw >> >> >> > >> >> >> > --- >> >> >> > >> >> >> > Need ODK services? http://nafundi.com provides form design, >> >> >> > >> >> >> > professional support, custom reporting, and software development >> >> >> > for >> >> >> > >> >> >> > ODK. >> >> >> > >> >> >> > >> >> >> > >> >> >> > On Thu, Oct 10, 2013 at 9:51 AM, Mitch Sundt wrote: >> >> >> > >> >> >> > > Not at this time. The examples of all the available widgets are >> >> >> > > here: >> >> >> > >> >> >> > > http://opendatakit.org/help/form-design/examples/ >> >> >> > >> >> >> > > >> >> >> > >> >> >> > > If someone writes a widget and contributes it back to the >> >> >> > > project >> >> >> > > under an >> >> >> > >> >> >> > > Apache 2 license, we will add it to the main codebase. >> >> >> > >> >> >> > > >> >> >> > >> >> >> > > >> >> >> > >> >> >> > > On Thu, Oct 10, 2013 at 3:07 AM, Jeffrey Dirawo wrote: >> >> >> > >> >> >> > >> >> >> >> > >> >> >> > >> Hi there >> >> >> > >> >> >> > >> >> >> >> > >> >> >> > >> Is there a slider widget for selecting a value from a range in >> >> >> > >> ODK? >> >> >> > >> >> >> > >> >> >> >> > >> >> >> > >> Regards >> >> >> > >> >> >> > >> >> >> >> > >> >> >> > >> JDChinga >> >> >> > >> >> >> > >> >> >> >> > >> >> >> > >> -- >> >> >> > >> >> >> > >> -- >> >> >> > >> >> >> > >> Post: opendatakit@googlegroups.com >> >> >> > >> >> >> > >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> >> > >> >> >> > >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> >> > >> >> >> > >> >> >> >> > >> >> >> > >> --- >> >> >> > >> >> >> > >> You received this message because you are subscribed to the >> >> >> > >> Google >> >> >> > >> Groups >> >> >> > >> >> >> > >> "ODK Community" group. >> >> >> > >> >> >> > >> To unsubscribe from this group and stop receiving emails from >> >> >> > >> it, >> >> >> > >> send an >> >> >> > >> >> >> > >> email to opendatakit+unsubscribe@googlegroups.com. >> >> >> > >> >> >> > >> For more options, visit >> >> >> > >> https://groups.google.com/groups/opt_out. >> >> >> > >> >> >> > > >> >> >> > >> >> >> > > >> >> >> > >> >> >> > > >> >> >> > >> >> >> > > >> >> >> > >> >> >> > > -- >> >> >> > >> >> >> > > Mitch Sundt >> >> >> > >> >> >> > > Software Engineer >> >> >> > >> >> >> > > University of Washington >> >> >> > >> >> >> > > >> >> >> > >> >> >> > > >> >> >> > >> >> >> > > -- >> >> >> > >> >> >> > > -- >> >> >> > >> >> >> > > Post: opendatakit@googlegroups.com >> >> >> > >> >> >> > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> >> > >> >> >> > > Options: http://groups.google.com/group/opendatakit?hl=en >> >> >> > >> >> >> > > >> >> >> > >> >> >> > > --- >> >> >> > >> >> >> > > You received this message because you are subscribed to the >> >> >> > > Google >> >> >> > > Groups >> >> >> > >> >> >> > > "ODK Community" group. >> >> >> > >> >> >> > > To unsubscribe from this group and stop receiving emails from >> >> >> > > it, send >> >> >> > > an >> >> >> > >> >> >> > > email to opendatakit+unsubscribe@googlegroups.com. >> >> >> > >> >> >> > > For more options, visit >> >> >> > > https://groups.google.com/groups/opt_out. >> >> >> >> >> >> -- >> >> >> -- >> >> >> Post: opendatakit@googlegroups.com >> >> >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> >> >> >> >> --- >> >> >> You received this message because you are subscribed to the Google >> >> >> Groups >> >> >> "ODK Community" group. >> >> >> To unsubscribe from this group and stop receiving emails from it, >> >> >> send an >> >> >> email to opendatakit+unsubscribe@googlegroups.com. >> >> >> For more options, visit https://groups.google.com/d/optout. >> >> > >> >> > >> >> > -- >> >> > -- >> >> > Post: opendatakit@googlegroups.com >> >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> >> > Options: http://groups.google.com/group/opendatakit?hl=en >> >> > >> >> > --- >> >> > You received this message because you are subscribed to the Google >> >> > Groups >> >> > "ODK Community" group. >> >> > To unsubscribe from this group and stop receiving emails from it, >> >> > send an >> >> > email to opendatakit+unsubscribe@googlegroups.com. >> >> > For more options, visit https://groups.google.com/d/optout. >> > >> > -- >> > -- >> > Post: opendatakit@googlegroups.com >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> > Options: http://groups.google.com/group/opendatakit?hl=en >> > >> > --- >> > You received this message because you are subscribed to the Google >> > Groups "ODK Community" group. >> > To unsubscribe from this group and stop receiving emails from it, send >> > an email to opendatakit+unsubscribe@googlegroups.com. >> > For more options, visit https://groups.google.com/d/optout. >> >> -- >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to a topic in the >> Google Groups "ODK Community" group. >> To unsubscribe from this topic, visit >> https://groups.google.com/d/topic/opendatakit/T2lwpswAIx0/unsubscribe. >> To unsubscribe from this group and all its topics, send an email to >> opendatakit+unsubscribe@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout. > > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to the Google Groups > "ODK Community" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.
ODK Collect v1.10+ supports range questions for integers and decimals and with a variety of appearances. The latest versions of XLSForm online and offline now support it as well (ODK XLSForm Online v1.0 and ODK XLSForm Offline v1.5).
For XLSForm examples, search for "range" in the All Widgets form. Supported appearances are vertical, no-ticks and picker.
If someone is looking for a quick contribution, documentation for these needs to be added --
https://github.com/opendatakit/docs/issues/38 :blush:
Default:
14 AM
No-ticks:
27 AM
Vertical:
10 AM
Picker:
25 AM
