I need to have a double entry for an ID to make sure user enter ID
correctly. I have two ID fields and set the second one to be "verify the
ID". is there a way or what is the best way to check to make sure both
values are consistent?
Wen
Forgot to mention that I am using Build developing form at
build.opendatakid.org. Thanks
On Tuesday, April 12, 2016 at 4:22:13 PM UTC-4, Wen wrote: > > Hi, > I need to have a double entry for an ID to make sure user enter ID > correctly. I have two ID fields and set the second one to be "verify the > ID". is there a way or what is the best way to check to make sure both > values are consistent? > Thanks, > Wen >Wen,
Use a constraint in q2 (e.g., /data/q2 = /data/q1)
-- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.On Tue, Apr 12, 2016 at 10:28 PM, Wen wenliang@umich.edu wrote:
build.opendatakid.org. ThanksOn Tuesday, April 12, 2016 at 4:22:13 PM UTC-4, Wen wrote:
Wen--
