Hi All
I have three different fields
entrant can either input in filed A or into field B or into field C
I want to create filed D equal to either field A or if field A is missing
then put in contents for filed B if B is also missing them put in contents
for field C
Any help will be much appreciated
**In sun set years education is not associated with standard of living and
medical care access; it is the the financial myosin and actin!!!
**** Don't give me fish, teach me how to fish
Kayoub K
0772656158 / 0703516660
Data Manager
Mujhu Research Collaboration
Mulago Hosp
Msc Enterprise Architecture
Hi Ayoub,
This can be solved using a nested "if" condition.
I would suggest setting field D to "calculate" and under calculation column
using "if(${fieldA}=null, if(${fieldB}=null, ${fieldC}, ${fieldB}),
${fieldA})"
Then you can use ${fieldD} in subsequent code.
Note:
- If field C is also missing then this will set field D to missing. If you
don't want that then you should have a default value for field D (e.g. 0)
- If you need field D to be a number (e.g. it's the area of farm) and need
to do calculations on it later, then you need to convert that to an integer
or decimal before using as I think the calculate field will make the result
a string by default.
Hope this is helpful!
On Friday, 3 March 2017 11:51:38 UTC+3, Ayoub Kakande wrote:
> Hi All
> for field C
> Kayoub K
> Data Manager
> Mulago Hosp
