Can I add a new follow-up question to choose one if there are 2 answers that have different follow-up questions? Example: 1. Do you like dogs? Yes or no. if Yes, then the next question is what breed of dog do you like? And if the answer is No, then the next question is why don't you like dogs?
Now i use odk build for windows 10
Hi @Rodiansyah46
You can achieve that adding all three question and then setting the relevance (for those two that depend on the first question) based on the first answer. Please take a look here https://xlsform.org/en/#relevant and let us now if you have any problem with it.
