Add polygon to geoshape map
Hi all,
I have a form in ODK collect where I use a ‘geoshape’ question to collect polygons. The polygons are then stored in an entity list. During a monitoring, we want to be able to modify the polygon (in ODK Collect) by selecting it from the entity list and re-do the mapping. Ideally, the former (erroneous) polygon is plotted on the map of the geoshape environment so that the enumerator can see what was the shape of the former polygon was, and how this should be modified. Ideally, the shape itself is modified, but I can also work with just plotting the former polygon on the map inside the geoshape and add a new shape. Is this possible? So (in resume) my question is: Can I add a geometry (polygon, line, point) from an entity list inside the geoshape question? And how could this be done? Thanks for clarifying.
You can't (yet) include other geometry in a geo question, so one effort intensive option is to use submitted geometry to create a tileset that will display and allow creation/ modification of your polygon.
Less effort and hopefully acceptable would be to select the entity item somehow (select, barcode, pick geometry from map...) and then have a triggered calculation in your geoshape question that looks up the geometry value you stored against the entity. The user can then view and modify as needed.
@ahblake,
Thanks. Yes, I already explored working with a imagery tileset as a background but creating these tilesets is too labour intensive for our case and it also requires some additional tasks (downloading those tiles every time they go to the field) from our enumerators (hundreds) which -I suspect- will not work in practice.
I read somewhere about the ‘pulldata()’ function in the calculation field. That could work(?). I will try. Thanks again.
I prefer instance lookups over pulldata, but both would work. There's an example instance expression in the official form template to refer to
@ahblake,
I can’t get the pulldata() option working. I have attached an excel of which I thought should be a solution. But this is not working. Is this approach the appropiate direction….?
odk_forum_integrate_polygon_geoshape.xlsx (18.6 KB)
Try replacing this calculation:
pulldata('monitoring_trees','geometry','search_label',${org_site_selection_monitoring})
with this:
instance('monitoring_trees')/root/item[name=${org_site_selection_monitoring}]/geometry
and add a trigger so it won't keep being recalculated, overwriting any geometry changes, as this:
But put them directly in the geoshape field, no need to use a helper calculate, and the geoshape doesn't need the placement-map appearance. And then save_to the entity geometry field (unless you have intermediate validation steps).
Of note - your form asks the user to walk around the field, assume auto recording / capturing GPS coordinates - if you want them to modify a polygon you would have to explain for the modification case to manually drag the points to make it more accurate/correct, otherwise delete points until all inaccurate points are gone and then start walking and auto collecting points.
odk_forum_integrate_polygon_geoshape.xlsx (17.4 KB)
Thank you @ahblake for sharing all these insights on what’s possible right now!
@Edmonds, it sounds like dynamic default likely does what you need in this case and should work today! You might also be interested in exploration we’re doing around showing existing geometry as context for shape/trace questions!
For those interested in displaying existing geometry as a reference while mapping new ones, we have a few open questions we’re exploring and would love your thoughts. If others have similar challenges, please share the scenarios you’re designing for and any feedback on the questions below.
Scenario examples
  • I'm capturing one of a farmer's fields, it's helpful for me to see the fields that have already been captured, especially if I'm not the one who captured the existing ones, so that I don't accidentally re-visit one or capture a geometry that overlaps.
  • I'm capturing the location of a household I'm visiting, it's helpful for me to see all households that have been visited so that I don't accidentally re-visit one
Open questions to better understand the needs
  • What would help enumerators understand that previously mapped geometry is reference, not something to edit?
  • When viewing a reference geometry, what (if any) additional information would be useful to access in the field?
  • Are there cases where enumerators need to see mbtiles or multiple sources of map context at the same time? If so, what are they and why?
  • How much control do enumerators need over showing or hiding reference geometries while mapping?
  • Are there situations where too much map context could interfere with the task?
  • When a map opens with both new and existing geometries, what should it prioritize showing? What is most helpful for the user to help orient?
I recalled this was brewing away, hence my '(yet)' :wink: , looking forward to it! I'll ruminate on the questions.
Hi @Aly_Blenkin
first of all I wish the team all the best for 2026 !
A first round :
Its appearance (specific stroke color, its thickness, transparency)
The ability to show/hide the "layer" of references geometry
Not easy. Something meaningful for sure. Regarding the first scenario, you're thinking about showing objects that have been mapped by others, so, for example, the name/id of the enumerator, the creation date, the "type" or any characteristic of the object
I think so, for example the parcels we own and the plots we follow...
But the most important thing for me is to better contextualize the new object I am mapping and to avoid mapping the same part of reality (one map context) twice, and the avoid geometry cleaning into the database. For example, mapping land cover, the forest I am mapping can share its border with a crop field I already mapped but can't overlay it.
This could help for sure, for example at a small scale if there is a lot of geometries that hide the background map.
Maybe depending on the scale of the map but also if two many objects have been mapped in the past.
The background map more than already mapped geometries.
@ahblake
Thank you so much! It works! Indeed, as you say: I need to consider whether it is practicle in some cases to drag points to another location manually. That could be a frustrating process in the field. Rather remap the entire polygon than dragging numerous points to another location. But in some other cases where minor adjustments are needed (or walking around the field again would be very time consuming), this manual adjustment may be very efficient. However, in any case, spatial context is missing by for example neighbouring polygons. So ideally, you would like to see the entire layer (showing all polygons, defined by a filter) so that the enumerators can see when their mapped polygon is overlapping a neighouring polygon. This is particularity valid for projects that have to map smallholder systems. I will answer the questions of @Aly_Blenkin .
@Aly_Blenkin
Answer: Color maybe. Showing non-editable polygons (reference layer) in another color then the editable polygon. Besides that: I see that at present, the editable polygon already appears as editable (by showing the vertices). This already explains to users which polygon is editable and which not.
Answer: Name or ID of the site. Or any other prefered label.
Answer: In our case: (up to date) true color satellite imagery as a background layer would be ideal. This is useful to check whether your polygon boundaries make sense. Especially valid in agro(forestry)/smallholder projects. But a global satellite imagery dataset might be too date ‘heavy’ and slow down devices.
A work-around for satellite imagery as a background layer could be to integrate a button that gives you direct connection to a imagery server where enumerators can define their AOI and then directly download imagery on to their device (keeping required technical skills as low as possible).
Besides having satellite imagery as a background layer, having a polygon (polygons already mapped for the project) layer as context is most useful (showing neighbouring polygons)
Answer: not that much. Keep it as simple as possible. The main focus should be that the polygons are ‘clean’: no self-intersection errors, no overlap with other polygons (snapping function…?), no duplicate poygons, polygons that ‘make sense’ (no needles, no strange shapes etc). This can be improved by: high resolution satellite imagery as background layer AND/OR polygon layer as a reference layer AND/OR functions that check the quality of the polygons during mapping (e.g. checks on self-intersections, overlap etc.)
Answer: Maybe. Keep it (as) simple (as possible) is my motto…:wink:
Answer: Color works best I think to distinguish. And/or using filled (50% transparent) polygons and (100%) transparent (only lines) could also be a good way to distinct layers.
    • Clear styling differentiation, while preserving styling (stroke/fill/thickness) that is applied to the geometries to identify them - a styling type applied to the capture/edit geometry not allowed to geometries perhaps (eg line style dashed)
    • agree with @mathieubossaert toggling it on/off for clarity, similarly to selecting tilesets.
    • additionally, the reference geometry should be filterable in some manner, don't necessarily want to see every item, maybe only those within a certain distance of the user or of a certain field value (for the 'building' set, show only 'hospital') etc
    • if the form could identify desired entity field(s) to display it's in the user's hands. But how is this actioned - if taps are creating points, tap-drag/tap-hold-drag is moving points, what action indicates 'don't create or move a point but tell me about the existing geometry I'm interested in?
    • Yes. for example a tile layer with drawing/imagery content combined with an entity geometry layer showing existing features to allow matching / aligning them or not creating duplicates as you can see it already exists.
    • A simple toggle on/off in the map view would cover most cases, and filtering would be controlled by a question(s) beforehand
    • if there are many and it slows the map down or they don't cluster and it's hard to see any map information as it's blocked by the reference information (but toggle off if so?)
    • existing = reference set and new = 'add/edit' geometry? the new geometry should be drawn at the top level / be the most visible. From bottom to top I guess it's: basemap / tileset / reference / add-edit.
As usual, I would say 'What @ahblake said'.
Some tricky problems well described regarding add /edit vs display info (especially if for any reason you DO want to overlap with existing geometry - a geo-Venn diagram! - scenario - existing geometry might show field boundary or habitat type, new geometry is for a sub-habitat, or species extent).
One possibility would be to have a 'toggle edit / info mode' button? But the screen is going to be filling up with all the icons! Maybe a multi-toggle button that cycles through:
new/edit mode || existing geometries visible || existing info shown on tap / mouse.
Base maps (offline layers) are really useful for ground truth of previously digitised geometries (desktop), and can be more flexible in terms of styling, to avoid confusion with ODK geometries.
It would be helpful for any styling of existing (submissions and entities) vs new geometry to be consistent - also between collect, Enketo and Web Forms
I'm starting to wonder if geo-widgets need to have a bespoke menu to show / hide the icons and reduce clutter while creating / editing / navigating? Is that possible with Collect and Web Forms (probably not with Enketo for well rehearsed reasons)
