ODK Developers,
JavaRosa supports custom functions via the IFunctionHandler interface,
which is handy. It looks like these can be added via the evaluation context
created in FormLoaderTask.java. However, there are two questions I have:
Why doesn't the core ODK team ever use this facility to add JavaRosa
functions? Rather, new ODK functions seem to be added by hand into
JavaRosa's XPathFuncExpr.java, in the ODK JavaRosa repo. This makes me
somewhat suspicious about the stability of the IFunctionHandler interface.
Best I can tell, my old ODK_Validate.jar from about a year ago let
unknown functions slide (i.e., it didn't generate an errors). With the
latest ODK_Validate.jar, however, you get errors like
"org.javarosa.xpath.XPathUnhandledException: XPath evaluation: cannot
handle function 'testfunc'" if you try to validate a form that includes a
calculate binding with an unknown function. Is my best option to build a
custom ODK_Validate.jar with my custom functions defined
in FormValidator.java's EvaluationContext, or would it be better to
generate an ODK_Validate.jar that goes back to not caring about unknown
functions?
I'd be grateful for any thoughts, as always.
Chris
The ODK team seeks to add new functions into the mainline javarosa code. In
that regard, I view the IFuntionHandler mechanism as a way of adding
non-mainline functionality, rather than extending the mainline.
I believe the issue with (2) disappears if you build a custom ODK Validate
that registers your handlers into the javarosa framework before you process
the form (if not, it is a bug). The tighter reporting was probably
something I picked up when I merged in post-1.0-alpha changes into our
javarosa branch. It wasn't anything that the ODK team directly set out to
change. On the other hand, it is useful to report unrecognized functions
to the user, as they often are mis-spellings of an intended function.
On Thu, Apr 25, 2013 at 2:36 AM, Christopher Robert wrote:
ODK Developers,
functions?
Chris
"ODK Developers" group.
Thanks, Mitch.
We'll fork odk.validate and register our custom handlers there. (Just one
more fork to maintain!) You're right that catching misspellings during
validation is useful. I've just submitted an issue regarding how they're
reported in XLSForm (since now the error is truncated to the point you
can't actually see what the error is) -- but that's an easy fix.
Thanks again,
Chris
In that regard, I view the IFuntionHandler mechanism as a way of adding
On Thu, Apr 25, 2013 at 2:36 AM, Christopher Robert <crobert@surveycto.com wrote:
ODK Developers,
functions?
Chris
