Hi @abdoul,
your problem is due to the fact that you have not defined a default language. When you added the "media::image" you use the same code, as you do to define languages. As your "media::image" does not have any data, all is empty. if you change the language and choose French, all your questions are there again.
To stop this from happening, add a column of "default_language" in the "settings sheet", and write French. 1acc56790681558fb9f14be84b3f31457a2479c2.xlsx (47.8 KB)
I have done it for your file.
