Adding score for each question
Hello everyone,
I'm looking now to update my excel sheet file that i used to create XML file by adding mark for each question and the last column will be the total marks .
is that possible???
many thanks.
Hossam.
Hossam,
Yes. If the questions are integer prompts (e.g., 1 and 0), you can
sum(${prompt_name}) to get the sum of the repeats so far.
If they are note integer prompts, you can use this trick that Chris
outlines at https://groups.google.com/d/msg/opendatakit/_O6Rjj2ymgo/4_8oPl4AAgIJ.
On Sun, Sep 21, 2014 at 2:06 AM, hossam.khalili985@gmail.com wrote:
Hello everyone,
is that possible???
many thanks.
Hossam.
